Sony WM D6C
Discussion in 'I found this!' started by ianthepostie, May 14, 2018.
  1. ianthepostie
    ianthepostie Active Member
    kent
    Just received this little beauty from Ebay. What an awesome machine! IMG_5788.JPG IMG_5789.JPG
  2. Costa32
    Costa32 Member
    Oporto
    As long as it works good, low WOW and FLUTTER and all that... its a beauty!
  3. Deliverance
    Deliverance Active Member
    United Kingdom.
    Nice catch looks clean .
  4. ianthepostie
    kent
    Its missing its battery cover but I can live with that.
  5. T-ster
    Best walkman period. Great score
  6. ianthepostie
    kent
    Just one question regarding AC adaptors. I saw a Youtube video demonstrating this machine and the guy said you should never use a generic 6 volt adaptor or you will fry the circuits. Only ever use the original Sony supplied one. Is this true? I've been using a multi voltage adapter and it seem fine. Should I stop using it?
  7. Simon
    Simon Active Member
    London
    It should be negative pin or you can blow the chip inside and then it would only run very fast and be useless unless chip replaced. I've never used an original Sony adapter on mine just 6v with a negative pin.
  8. ianthepostie
    kent
    Yes I checked and double checked that I had the polarity the right way round!
  9. ianthepostie
    kent
  10. stuck-in-time
    Jakarta, Indonesia
    Just today my first WM-D6C arrived, and boy does it sound good!
    Got mine for a decent price, but I noticed that the motor runs even when the unit's off. Upon reading up, I found out that this is a symptom of a damaged servo IC. It still sounds good though, so my question is, is my unit living on borrowed time?
    Will the damage worsen or will it stay so? I can live happily live with it at the moment, sounds good enough for my ears and I just need to remove the batteries after every listening session.
    ianthepostie likes this.
  11. rcpilot23
    rcpilot23 Active Member
    Perth
    Hard to say as I just repaired a D6C this week which I purchaed on ebay
    The previous owner plugged in a 9V ac adapter and fried the DC to DC converter and the Sony CX20084 speed chip
    I repaired the DC converter and replaced the speed chip and now it sounds great
