Aiwa Series 30 Mini Hi-Fi System (1980) - January 2019
Discussion in 'Home Audio Gear Chat Area' started by nickeccles, Jan 20, 2019.
  1. nickeccles
    nickeccles Well-Known Member
    Littlehampton West Sussex
    Ah The classic Aiwa Mini HiFi Systems from the early 1980's!!
    Who didn't want to own one back then??
    So beautiful desirable with full size HiFi separates performance, these were testament to the astonishing design & high quality build coming out of Japan at the time...........
    I have been searching for quite some time now for a set of these components & after a long time had managed to secure for myself a System 30 series comprising of tuner, amplifier & cassette deck from different sellers & mostly working!!
    The cassette deck didn't work of course whereas the tuner & amp needed only a good clean up & service to get them working perfectly!
    The cassette deck is extremely complex & somewhat difficult to repair & access due to it being so small & took quite a while to clean up & re-belt, all the belts had disintegrated leaving no clue as to how they even went on & indeed how the thing worked at all!!
    The incredibly ingenious mechanism was designed in a way to provide sterling stability from the ground up - huge heavy flywheels for playback & fast forward/rewind & a clever tape counter/hall senser mechanism that passes from the bottom of the deck to the top via pulleys & belts!!
    This is what took me the longest time to repair - waiting for a proper belt kit which turned out to be completely wrong in the end causing a real headache & producing many symptons that all turned out to be red kippers! :( :( :(
    Some 3 months later & after being led on a wild goose neck, I worked out over many sessions of working on it, that the flat capstan belt & the reel drive belts were completely wrong leaving me as I thought initially up the canoe without a boat & very frustrated!! I was beginning to wish I'd never seen one of these systems again! :O
    Some three months later & after lots of pondering & trying to work out what I had done wrong, I had a deck that played very badly & when it came to fast winding, the deck made an awful clattering sound, almost a cavalry noise akin to the Charge Of The Bulb Brigade!!
    This was becoming a real headache & not the doodle I had originally though this would be...........
    In an eggshell, as well as the complicated belt arrangement, both large flywheels have rubber inserts around part of the rim that drives a little idler wheel, one for wind & rewind respectively, a very clever & neat idea indeed - Until the idler tyres & the recessed rubber trains around the flywheels fail :(
    If only the shoe was on the other boot I thought as I spent a great deal of time trying to work out what to do next as I gazed at the upturned deck - it's impossible to operate the deck when removed from the chassis without shorting out dozens of wires & getting the moving parts caught up in the tentyhooks which of course just adds to the frustration............
    It was more than once that the cassette deck was placed in a box & "Filed Away" until another day when I could look at it again with a fresh pair of glasses!!
    To cut a long tale shorter, I eventually replaced all the rubber idlers resulting in all modes being restored & functioning correctly! :)
    So I am finally approaching the home bend & time to begin reassembling this nightmare of a cassette deck & begin cleaning it up & testing through my headphones before replacing the top cover & giving it a new set of rubber feet to replace what remained of the almost 40 year old ones :O
    With a now working cassette deck, all that remained was to source some original early 1980's mini Speakers!!
    Having wanted a pair of silver Realistic Minimus 7's for the Aiwa system, I soon gave up as finding a minty silver pair in the UK proved to be a wild swan chase - Plenty over the pond & at decent prices too but just to expensive to import a pair of these heavy little speakers to the UK!
    While searching a few days later an old friend called round to distract me but it was great to see her after a long time, we always laugh a lot - She's a real tonic water.......
    Resuming my search the next day, I found a pair of Tiny Monitor Audio Baby 1's..........Never heard of these tiny speakers before - They are like an uprated version of the Minimus 7's, same aluminium casing & same configuration, a 4 inch woofer & a 1 inch soft dome tweeter with a real crossover circuit too!! They are very heavy & these turned out to be in near mint condition when they arrived - Yes I couldn't buy them quick enough & I am so happy with them! :)
    This little Hi-Fi system was always intended to be used in my bedroom as the Aux input would perform the stereo sound from the TV in there, so it was time to begin the install & see how she performed.........
    No surprise of course to report that the results are superb - delivering solid quality audio on all sources with a startling stereo soundstage!! The amp is powerful & punchy while the little speakers sound great! I am considering an active subwoofer though as the system could do with the lower frequencies given a little help...........
    The Monitor Audio's really do compliment this little system though it has to be said!!
    For now though, that's the end of the story & a dream of mine since 1981 to own an Aiwa mini HiFi system!!
    Et Viola:
    Aiwa A30 Mini Compo Stereo Amplifier 28 October 2018 (1).jpg Aiwa A30 Mini Compo Stereo Amplifier 28 October 2018 (2).jpg Aiwa A30 Mini Compo Stereo Amplifier 28 October 2018 (3).jpg Aiwa A30 Mini Compo Stereo Amplifier 28 October 2018 (4).jpg Aiwa A30 Mini Compo Stereo Amplifier 28 October 2018 (6).jpg Aiwa A30 Mini Compo Stereo Amplifier 28 October 2018 (7).jpg Aiwa A30 Mini Compo Stereo Amplifier 28 October 2018 (10).jpg Aiwa Series 30 Mini Hi-Fi System (1980) Restored - October 2018.jpg Aiwa Series 30 Mini Hi-Fi System (1981) Restored - October 2018.jpg Belts - 15 December 2018 (1).jpg Belts - 15 December 2018 (3).jpg Cassette Deck Repair - November 2018 (2).jpg Cassette Deck Repair - November 2018 (13).jpg Cassette Deck Repair - November 2018 (14).jpg Cassette Deck Repair - November 2018 (17).jpg Cassette Deck Repair - November 2018.jpg Monitor Audio BM-100 Mini HiFi Speakers - November 2018 (2).jpg Monitor Audio BM-100 Mini HiFi Speakers - November 2018 (3).jpg Monitor Audio BM-100 Mini HiFi Speakers - November 2018 (5).jpg Monitor Audio BM-100 Mini HiFi Speakers - November 2018 (7).jpg My Bedroom In 1981 - 6 November 2018.jpg Pre-Restore - 6 November 2018 (1).jpg Pre-Restore - 6 November 2018 (3).jpg
    Hi-Res Images Here:
    https://onedrive.live.com/?id=BEA218B70F2B18D1!32441&cid=BEA218B70F2B18D1
    Back in the mid 1980s an XR4i driving manager I worked for had a similar Mini System which he was very proud of. It might have been an even smaller Hitachi though. Back then these were definitely the sort of system for highly paid managers rather than lowly paid apprentices.
    Looking to the left "10-4 good" buddy. As I explained in my introduction Longman was my CB handle.
    I would have loved that Harvard back in the day but had to make do with a 2 channel Handheld.
    I did have about ten car rigs at one time though including a Tristar 747 :laugh:
    Looks great nickeccles, I don't think AIWA got much love over here due to muscle car syndrome where everyone thought bigger was badder so everyone wanted something that was huge, no matter what the quality. These little systems are so cool and kind of in style now a days since everyone wants smaller systems that aren't so obvious. There's so many AIWA Versions it's hard to keep track of them.
    Hopefully I'll be sharing some new finds soon, just have to pick them up and we really need to start a thread on mini-systems, they're a kissing cousin away from boomboxes.
    And yes that CB is a great touch, I've got a few tucked away, pretty much a lost relic of the 70's but so cool. I feel like when people are sick of being tracked with their phones, they'll try to find old CBs to communicate without monitoring by big internet.
    nickeccles likes this.
  4. lupogtiboy
    lupogtiboy Well-Known Member
    I have one of these waiting to be restored as well as a System 22 that needs new belts too, so not looking forward to that! Nice to see it back up and fully functional though. I scored my System 30 at a bootsale for £15, alas with no speakers but I do have some small Goodmans speakers that will be perfect for this.
  5. DutchNick
    DutchNick Active Member
    United Kingdom
    Hi lupogtiboy,
    I restored a Aiwa 22 system 18 months ago. The belts were not hard to find on eBay, the trader was BlackReel-Audio HIFI (I hadn't hear of Marian Mihok at that time - but I'd check with him first). Somewhere on the net I found the attached picture of the tape path, which was very useful as tracing the tar remnants around the mechanism was going to be no fun :)
    Cheers
    Nick
    MikeWalkman and lupogtiboy like this.
  6. David Waterman
    David Waterman Member
    London
    gorgeous...I wanted one of these, and I still do!
  7. lupogtiboy
    Thanks for the info! I will get these up and running!
  8. Longman
    It's a Buick, maybe a Sunfire?
    The brochure is nice, there's lot's of neat cases and it shows the even more rare speakers. I think a lot of people skipped the speakers and just used what they had or something cheaper.
  10. autoreverser
    just one second matey:
    tell me what model is that portable, i might need it to survive :swoon
    Dawg_Ciao and nickeccles like this.
  11. nickeccles
    Which portable? The CB radio? Harvard 410T from 1982
    The walkman clone is Unisef TU-1
  12. autoreverser
    UNISER :worship:
    Is that Unisef's older cousin?
  14. autoreverser
    Unisef and Uniser are bro and sis, anything else might be Unisex :smoke
  15. Longman
    If you were wondering why I was searching for an Aiwa catalogue I bought this.
    https://www.ebay.co.uk/itm/AIWA-A10...596685?hash=item2f2c3c100d:g:re8AAOSw~5ZcROH6
    When it arrived my first thought was "Honey I've Shrunk the Hi-Fi.
    It is even smaller than Nick's system.
    The 10W per channel seems to be plenty for normal listening.
    I have been trying it today with my Technics SL-5 deck which itself has almost the same footprint as an LP cover (315 x 315mm), and some small "Gale" loudspeakers.
    All I need now is the matching cassette deck and a Buick Sunfire :nodding:
    nickeccles, Mister X and Simon like this.
  16. Chestnut
    Chestnut Member
    Cambridge UK
    This is a great thread, so thanks for sharing your experiences nickeccles. I'd appreciate your advice - I have exactly the same system, and it all works fine (having replaced the belts with correct sized ones and correctly as shown in the image shared above by DutchNick), but with the exception of one issue: when I fast forward, or rewind a tape, the winding speed (and hence the speed the tape counter changes) can be very slow or even grind to a complete halt, better with some cassettes than others (even when I've wound them full length back and forward on another machine to 'loosen' them). I believe this issue is caused slippage between each of the two idler wheels (which are visible after removing the top of the case, inside the cassette housing) and their respective spindles which I think come together when ff or rw keys are depressed. Correct me if I'm wrong but it seems to me that the rubber edge of the small idler wheels loses grip over time, so can't turn the spool so well, and slips. I saw your comment in your original post, suggesting that you'd 'replaced all the rubber idlers'. I wondered specifically how you did this...?
    Chestnut, are you looking for sources, or how to actually replace the the idlers? I've had problems with oddball sizes and have used automotive style tubing in a pinch. Rubber rejuvenator sometimes works on really hard, but still solid wheels and might buy you some time but I've also had it melt really old small diameter wheels. I bought a sheet of rubber with the intention of making my own but haven't really seen or read how they mill or grind it down.
  18. Chestnut
    Chestnut Member
    Cambridge UK
    I'm wondering exactly where the person who started this thread (who like me is in the UK) sourced replacement idler tyres for the Aiwa SD-L30 cassette deck, in what sizes, whether it was a simple friction fit to the wheels or if it was trickier than that to replace them. In other words, if the repair was successful, I'd like to be able to 100% replicate it in terms of parts and methodology.
    Try these guys, I haven't used them but Marian has contributed greatly to this forum.
    https://fixyouraudio.com/
    If your trying to do it yourself, I think guys are mounting a grinder on a lathe to get the right size, I was thinking about trying that or seeing how it would do in a drill press and a sanding block.
    Chestnut likes this.
  20. MUTE AUTO
    MUTE AUTO Member
    Sichuan, China
    Very beautiful machine.
