1954 Tandberg Model Type 2: the Norwegian Craftsmanship.
Discussion in 'Other formats: DCC, MD, Reel 2 reel, CD...' started by Retro Audio Museum, Oct 27, 2024.
  1. Retro Audio Museum
    Retro Audio Museum Well-Known Member
    The Netherlands
    In 1954, the Tandberg Model Type 2 introduced audio recording to living rooms worldwide, marrying Scandinavian design with groundbreaking versatility. This tape recorder wasn’t a mere gadget - it was a tool for capturing life’s sounds with finesse, available in four distinct flavors to suit a full range of needs and tastes.
    The base Model 2 was straightforward, delivering quality sound in a sleek, user-friendly form. Then came the Model 2T, like the one in the photo, which featured an unusual clock-shaped built-in counter, operating on the same principles as a speedometer on old motorcycles. The Model 2F upped the ante with a foot-pedal remote control, bringing hands-free convenience to the mix. For the audiophiles, the Model 2 Hi-Fi delivered an extra playback speed, enabling high-quality audio clarity that was a rarity in home devices at the time.
    Designed for a global audience, the Model 2T adjusted seamlessly to international power standards, running on 100-120 Volts or 200-240 Volts AC at both 50 and 60 Hz. It offered dual playback speeds—9,53 см/sec and 4,76 см/sec—allowing users to switch speeds mid-recording or playback, a feature that lets creativity flow without interruptions.
    The sound quality was no afterthought. The Model 2T brought playback frequencies to life with a frequency response of 50 to 4000 Hz at its lower speed (4.76 cm/sec) and 40 to 8000 Hz at its higher speed (9.53 cm/sec). And with 1200 feet of twin-track tape, it delivered up to 128 minutes of recording time per side at lower speeds, perfect for lengthy interviews, music sessions, or whatever else its users could imagine.
    Flutter and wow were held below a 0.2% deviation at the faster speed, while distortion levels remained under 4% at peak levels. A 50 dB signal-to-noise ratio ensured that each recording would playback with clarity, even at maximum volume. Adding to the magic, the Model 2T’s unique “Electronic-Eye” tube, an EM71, served as a visual guide, softly glowing and closing fully at the highest recording levels—a sight to behold in dim lighting.
    The Model 2T was no ordinary tape recorder. It had live mixing capabilities, blending microphone audio with radio signals, and could even serve as a public address amplifier for lectures or small concerts. Fast winding was equally impressive, with the recorder able to zip through a full 1200 feet in just three minutes, carefully engineered to protect the heads and minimize wear.
    Practicality was built into every inch of the Model 2T. Measuring 15 inches long, 11 5/8 inches wide, and 6 5/8 inches high, it was compact enough to fit in small spaces while offering a manageable heft at 21 pounds. Its built-in speaker allowed for convenient monitoring, though it could connect to external speakers or earphones for a more tailored listening experience.
    Operating the Model 2T was as intuitive as it was enjoyable. With easy-to-understand controls and a speed selector that allowed for instant switching, this recorder transformed every user into a sound engineer. More than a machine, it brought an experience—a seamless blend of design, innovation, and pure, Scandinavian craftsmanship.
    #tandberg #type2
    overmodulated, thid and Mister X like this.
    They sure used a lot of plastic for late 50's, early 60's. Going into the 70's most Japanese Machines were still mostly metal, maybe the little Hong Kong Portables were plastic but you didn't see as much of it.
    Retro Audio Museum likes this.
  3. soluna
    soluna Active Member
    That`s really good condition, especially the plastic parts, and it looks like child equipment ( the mic ! - seems to record sound in early telephone quality ;-) )
