Aiwa HS-J202MII screeching sound
Discussion in 'Tech talk' started by JUAN ANDRES MONTIEL DIEZ, Aug 26, 2024.
  1. JUAN ANDRES MONTIEL DIEZ
    Spain
    I'm going crazy with this issue, after recapping the radio works perfect, clear and powerfull sound. Tape source has an horrible screeching sound, I was reviewing mech earth, caps solders, tape/ radio and Rec/Pb switchs, all seems to be ok, desoldering head's ribbon the issue continue. Recording from radio the sound it's ok. It's like the mic introduce a parasite signal. The screeching is very high, at 0 volume level you can hear it, and at 2 level is almost unbelievable.
    It must be an common issue, I have another donnor unit with the same problem.
    Any Ideas?
