Battery Connectors
Discussion in 'Tech talk' started by Brandon, Oct 25, 2017.
  1. Brandon
    Brandon Member
    Sheffield
    Sorry if this has already been asked....
    Over the years I have purchased many Walkman style players to find when the battery cover has been removed the batteries are still in there and have leaked and in most cases eaten the connectors.
    These should be easy to replace , where do you guys use ?
    Any part numbers associated that are easy to fine instead of trail and error on size and fit?
    Thanks in advance B
  2. Ball000
    Ball000 Member
    Daoulas
  3. speedy2.0
    speedy2.0 Active Member
    Might sound odd but I’ve found, in the case of my d6c battery box, dropping it in beaker of vinegar for a few hours did the trick. Then give it a good wash. Obviously don’t put any circuitry in there but the rust and residue will lift off almost immediately
  4. Brandon
    Brandon Member
    Sheffield
    Hi
    I use white Vinegar on most but sometimes the spring or contacts are gone completely beyond any repair .
    so sourcing some replacements would be the goal.
    Brandon likes this.
