Bushing Lubrication
Discussion in 'Tech talk' started by Steve Grant, Dec 1, 2024.
  1. Steve Grant
    Steve Grant Member
    Vancouver British Columbia
    The capstan and pulley bearings in the Aiwas I've had apart, consist of what looks like a chrome steel shaft through a brass bushing. There is zero evidence of these bushings ever being lubricated or wearing.
    Does this combination of metals create a bearing with extremely little friction and wear?
    Would lubricating them eventually cause problems as the lubricant ages?
    Your thoughts are appreciated.
  2. Michiel
    Michiel Member S2G Supporter
    I would leave it dry and clean when the device is stored for a long time. You can always lubricate the bearing with some oil when you want to use it later. There should be some lubricant in there when its working. A brass bushing with steel shaft is never a lubricant-free design.
