Cassette Rewinders / Winders
Discussion in 'Chat Area' started by speedy2.0, Mar 11, 2019.
  1. speedy2.0
    speedy2.0 Active Member
    7EFF3263-D398-4A68-AE72-17018F017604.jpeg 5ED739B2-8880-40C5-AAFB-FDF18BCA15C2.jpeg C2B25FBA-2874-453F-ADD5-04F24611754A.jpeg 02367BAD-00EF-4EC7-ACA5-5DB561E1AB87.jpeg so as part of a purchase of a UHER 160AV, this Maxell EW-340 rewinding machine was included. I have never actually heard of a gadget for one specific purpose like this, but here it is! It runs quite slow as it happens but I’ll take it apart later and give it a good clean. Currently it rewinds a c30 in under a minute but that’s actually not much faster than my D6C, so hopefully it can be improved.
    Speed test:
    1min30 for c-60
    2min20 for c-90
    Also, the SA90 in the above picture got jammed. Unit will need a belt change!
    Further info: unit appears in the 1982 Maxell catalogue
  2. Reli
    Mister X and speedy2.0 like this.
  3. speedy2.0
    B6FF5E76-B3B0-48B2-BA61-8D19FA68EB2C.jpeg 3405EFE8-C797-4E7A-BCF2-0212EF2C1986.jpeg D25A5FFD-10F2-42CB-A248-4E349B05923B.jpeg 27C3270E-5404-40C6-803F-9AF5B229ECF2.jpeg C00CB292-9BF5-4AC1-823E-5E4FF901FDCB.jpeg I also found images of various winders. There is a difference between rewinder and winder, but it’s very obvious what they do!
    Also, I may be able to use a magnet on the ew 340, and turn it into an eraser. I would imagine a small neodymium magnet would be strong enough if placed correctly.
  4. speedy2.0
    Also here is techmoans excellent video:
    Thanks! These are so cool, I have to admit, I've never seen one up close yet.
  6. T-ster
    Ha, very cool, i dont see the point of a dedicated battery powered winder but the manual ones are cool
  7. speedy2.0
    I took it to pieces today for a clean. It’s literally a motor at 90 degrees to the capstan with a belt, and then a belt from there to the further capstan. Tiny PCB, 4 AA batteries. I quite like the soft stop feature, there’s a tiny rubber tyre which brings the wind to a stop before it rips the tape. I imagine a hand winder you’d have to be careful to not destroy the tape with over wind
  8. speedy2.0
  9. speedy2.0
