CD runs only when tilted - Panasonic RX-DT9
Discussion in 'Tech talk' started by rupi99, Feb 9, 2021.
  1. rupi99
    rupi99 Active Member
    I have a strange problem with my Panasoniy RX-DT9.
    When the device stands normal horizontal, then the CD starts to spin but does not play. If I skip some songs forward, then sometimes the music starts, but often is looping or even jumping back.
    But if I tilt the device a little bit, then the CD runs from the beginning to end without any problems.
    Here is a short video:
    Any idea, what could be the root cause? A wear out in spindle motor bearing?
    bronco and Jorge like this.
  2. Jorge
    YES! At least with Sony Discmans this is the first indication that spindle motor is worn to death: plays when at an angle but skips when level. How does it play when upside-down? Sometimes an over-eager fingers push CD platter further down the spindle. But, again, most probably it is the worn spindle motor.
    Cheap'n'Dirty temp fix would be a droplet of oil, applied with a needle/syringe onto motor shaft under the platter. If motor has hole(s) for the bottom bushing, then some oil goes there too:
    New motor (Mabuchi motors with different shaft lengths available from eBay, some even with a platter as this above) should fix the problem permanently. Contact me or kaosuncd.com on how-to: it is a bit tricky but not too difficult :)
    rupi99 and stuck-in-time like this.
  3. rupi99
    Hello Jorge,
    thank you very much for your advise. This is very helpfull.
    I will try at first the droplet of oil. But in any case I will order also a new motor as it is so cheap. The RX-DT9 is in any case worth to keep it running.
    Would contact you, if I need further help for motor replacing.
