Fiio CP13
Discussion in 'Chat Area' started by Chris_D, Dec 6, 2023.
  1. Chris_D
    Chris_D Active Member
    ooooh :thinking:
    Radio Raheem, Valentin and Mister X like this.
    I'll go with colorful and boxy anyday over egg'd and black. Most of these guys don't have a lot to work with, the transport just needs a shell.
  3. Chris_D
    Be interesting to see the specs when they're revealed.
    I'm not expecting anything stellar. But you never know....
  4. Emiel
    This mechanism will most likely be the dreaded one described by Techmoan, right?
  5. Radio Raheem
    well it looks a step in the right direction for sure but time will tell
    Interesting to see a walkman from Fiio, didn't expect this. From pictures the design looks promising and would assume it will be somewhat similar to the WeAreRewind one, but smaller.
    The fact they say it's a "high-res" player makes me think they will use some good low noise amplifiers in it. If that's the case it's good news.
    Not including record functionality, speaker and mic is a step in the right direction suggesting they're focused in making a good player not in features that are not needed.
    The mechanism, won't expect anything else than the Tanashin-type one, but there may be a better implementation of that mechanism depending on price (which I expect to be in the 200euros range).
    However right from the start noticed some things I don't like:
    1. Non-removable battery. Ok, I understand the device looks better without having a door, I understand that door can be lost (this has a simple solution), but these are minor things which cannot justify it.
    Also, I can't see any screws on the case so have to assume it's similar to the WeAreRewind one. Would prefer AA/AAA batteries (or at least a user removable 18650) + the integrated USB-C port.
    The advantage of lithium vs NiMH is not really needed in this application, not to mention once the battery is discharged one will have to wait to charge before being able to use the device.
    With AA, I can simply swap the batteries with another set that is already charged (which is what I do on my vintage walkmans) eliminating this incovenience.
    2. No 120/70μs EQ switch. Ok, I understand all new tape releases are on TYPE I, but if it's a "high-res" player I would assume they target a larger market and being Fiio
    would also expect them to do things differently than they have been done before. Maybe there's an automatic tape switch inside the cassette compartment, but I doubt it.
    This is way too simple (and cheap) to implement and there's nothing proprietary behind it, so really no reason not to do it.
    Emiel, Deb64 and Radio Raheem like this.
  7. Radio Raheem
    well i don't do rechargeable so that's me out straight off the bat:frown:
    thanks for the update valentin:)
