greetings
Discussion in 'Introducing myself' started by da_funk, Nov 27, 2017.
  1. da_funk
    da_funk New Member
    Hi Folks!
    Finally set up an account on this amazing forum, the community already helped me out on several walkman restoration Projects :)
    I really enjoy bringing back old cassette players and wanted to share some of the experience fixing old walkmans with the forum, since it already helped me al lot when i got stuck at a repair attempt ;)
    Current lineup:
    Sony WM-D6C, the most reliable portable cassette recorder i've seen so far
    Sony WM DD2, awesome sounding little Design Icon from the 80s, works but has the imfamous Center gear problem, might fix that this year....
    Sony WM D3, currently dismantled for repairs, still struggeling with the small broken gear... most complicated walkman i've ever come across ;)
    Toshiba KT-4176 "Walky", just received a donated drive belt from a Sony WM-EX662, works surprisingly well.
    Currently not working: Sony WM-EX662 and WM-EX510
    Sony Discman D99, nothing that special, but i like the bulky design. I had to resurrect it already 2 times, it's quiet fragile...
    TD-X502 Tape Deck
    and an old Revox A77 Mk IV
    Cheers!
    Max
  2. TooCooL4
    Welcome to Stereo2go Max, nice units you have there :thumbsup:
  3. Jorge
    Welcome! Beautiful Revox you've got there... What is downstream of the Beauty??? Did you restore it yourself?
    D-99 is a bummer, same as D-90 but with 1-bit DAC, the proof that Evolution is not always Progressive...
  4. walkman archive
    Nice units for sure. I love the design of the D3.
  5. Boodokhan
    hello da_funk
    welcome to S2G
    Thanks for sharing the pictures.
  6. ianthepostie
    ianthepostie Active Member
    kent
    Welcome! And thanks for sharing pics!
  7. Mystic Traveller
    Welcome to S2G! :)
  8. da_funk
    da_funk New Member
    The A77 was already in pretty good condition when i got it, the only thing was a loose contact at the power plug. So far it's perfectly reliable, just needs some clean up once in while...
    It's actually easier getting new tape reels than finding decent compact cassette Tapes ;) It has Dolby B, but I never use it, the hissing level is already low enough. I might replace the Audio In and Outputs to modern connector spacing, since the newer chinch cables are a bit wider than they used to be in the 70s.
    I love the WM-D3, hope to get it back to life soon!
