Hello from SF Bay Area .. just finished fixing WM-D6 that had spent 40 years with me
Discussion in 'Introducing myself' started by Chang Song, Mar 15, 2024.
  1. Chang Song
    Chang Song New Member
    North CA, US
    Hi all!
    The contents here (esp. by Deb64) helped me greatly in the process of fixing my good old buddy WM-D6. About 4 years ago, I actually gave up after trying to fix the speed issue (and had bunch of torn cables from the board in the process, not to mention completely busted DC-DC converter). I put it in a time machine (a shoe box really) in the hope a future self would be able to get suddenly smarter and magically cure it out of pure magic.
    Well the information here made me definitely a better wizard and I was able to fix WM-D6. Now I almost memorize WM-D6 service manual's circuit diagrams and wiring diagrams after spending full 36 hours on them.
    In the process, I found a really good way to replace the problematic DC-DC (6v - 11v) step up converter without spending $40 on eBay or go through a lot of repair job on the old circuit. Will post it as a new thread in the tech forum and link it to the existing post on DC-DC converter repair that already helped me greatly. This is list of what I had to do:
    * Follow on Deb64's post on CP602 repair by replacing one NPN transistor and one FET transistor
    * Just remove mute module (CP301) -- new unit is coming from eBay
    * Replace DC-DC converter with an easy to obtain MT3068 DC-DC converter (they are less than $1 per unit)
    The MT3068 DC-DC converter is better than original design in many ways
    * It holds output to set voltage (configurable by potentiometer) for wide range of input voltage
    * High energy efficiency (>92%)
    Benefits
    * Battery almost drained -- but the walkman runs and sounds good!
    * We can just wire adapter plug to widely available 5V USB output and the walkman runs!
    * Low white noise (with proper capacitors added on)
    Thank you for keeping this amazing forum and I hope to contribute more!
    Best,
    Chang
    Welcome to the forum! Thanks for your contributions in keeping the old stuff running.
