Hello guys, bought my first walkman. Sony WM-7
Discussion in 'Introducing myself' started by Jairaj, Dec 1, 2024.
  1. Jairaj
    Jairaj New Member
    India
    Just bought a Sony WM-7 for cheap in dead and as-is condition. Im going to need some help from you guys.
    Welcome to the forum, good luck with your repairs.
  3. Michiel
    Michiel Member S2G Supporter
    Open it slowly and see if you can find out what's going on with it. I think it's quite a complicated Walkman to start with. So don't beat yourself up if you don't succeed right away. Welcome here :)
    Hello and welcome to the forum @Jairaj !
    There are quite a few common problems with this walkman, hence why recommend checking post #8 here: https://stereo2go.com/forums/threads/list-of-walkman-portable-recorders-common-problems.7535/
    First things to do are checking/repairing the table reel clutches and installing a new belt (70mm x 0.8mm) https://fixyouraudio.com/product/sq...8-for-cassette-players-and-cd-players-8lkb2l/.
    This belt works better than the one advertised as for WM-7 which is a 0.6mm thickness and significantly more elastic. Elasticity doesn't help here because out of round gears, which create uneven load.
  5. Jairaj
    Jairaj New Member
    India
    Hello @Mister X @Michiel @Valentin . I've gone through all posts regarding the WM-7 and scoured the internet trying to gain as much information as possible about this walkman before I start doing anything. Also i think the belts on this unit were replaced recently, it looks fine. I have posted detailed information about my walkman and the issues im facing on the Tech Talk section. Looking forward to get this walkman working with help from you guys!
