My first 'retrobrighting'... it worked out!
Discussion in 'Tech talk' started by walkman archive, Nov 4, 2019.
  1. walkman archive
    As you know fellows, some of our beloved gadgets become yellowish over the years. White and light grey plastics turn brown-yellow with time.
    This is most seen in 80s computers.
    Ok, so I learnt how to apply a technique called retrobrighting to this plastics thanks to The 8-bit guy and decided to try.
    After trying with some of my beloved walkmans, I tried with this. As you can see, it fade intro a very ugly brown-yellow (call it how you wish):
    I applied this treatment to the upper part, and here's the result:
    I was very surprised with the result. So I moved one and tried with my smaller kid's walkman, a very simple Panasonic:
    What you need is hydrogen peroxide cream like this:
    You have to cover it with cream, with your hands. Then cover it with a thin plastic film and let it under direct sunlight for some hours. For this I dissasembled it, removed the mechanics and electronics:
    Finally, remove the plastic film and clean with water. After assembling, this is the result:
    So, yeah it works!!
    Next step...
    More news soon...
    [UPDATE]
    The final result:
    http://stereo2go.com/forums/threads/sony-wm-f107-total-restoration.5186
    thid, sickly_b, Ball000 and 6 others like this.
  2. Reli
    Does this only work on UV yellowing, or could it work on nicotine yellowing too?
  3. walkman archive
    No idea...
    Do you see any of the printing fading from the process? I wonder if tanning or ultraviolet lights would work, summer is short here.
    Sly. likes this.
  5. walkman archive
    Absolutely not. No fading of any printing. It worked just great.
    It probably works under UV lighting.
    Mister X, Sly. and Jorge like this.
  6. Ken80s
    Ken80s Well-Known Member
    Malaysia
    Wow, the result is significant. It's a great way to revive electronic items made of plastic. But where can I buy this Oxigenada cream? What does this product use for originally?
  7. stuck-in-time
    Jakarta, Indonesia
    Oh it's safe for it to touch the other colored plastics as well? I was under the impression that this was safe only for the white parts.
  8. walkman archive
    Yes, indeed.
    In english is hydrogen peroxide cream, while in spanish is "agua oxigenada". H2O2 in chemical language. I bought it in a professional hair products store. I think it's used to apply coloration to the hair.
    Take a look at this and you'll see the process. He uses UV light but direct sunlight is totally enough. I've used sunlight.
    It seems it doesn't affect at all.
  9. stuck-in-time
    Jakarta, Indonesia
    I wonder if these works with the grey/black-turned-brown plastics as well...
    Nak D likes this.
    stuck-in-time, you may want to try "Forever Black" or one it's many competitors. Made for faded plastics on cars, I use it and it works great initially but it will either fade or dry off after a few weeks time, going back to faded condition. I've used a few different brands and haven't found a favorite yet. I saw Techmoan tried it out on his YouTube Channel. The auto detailing forums have a lot of different ideas for restoring plastics, they might have alternatives for your part of the world.
    I've watched a lot of 8-bit/8-bit keys and he has several other ideas for labels, decals and overall cleaning. He also fixes vintage equipment with basic skills, highly recommended if you like 80's electronics.
    stuck-in-time likes this.
  11. Boodokhan
    excellent
    I never had any luck with this process ( because i didn't follow the sunlight exposure).
    is that hydrogen peroxide cream available on Amazon or ebay?
  12. walkman archive
    Sunlight (or UV) is the key to sucess, my friend :nwink:
    I bet so. That guy uses this one, as you can see in the video:
  13. walkman archive
    I've never heard about that product. But does it fix faded black plastics that become grey or also yellowed whites?
    Anyway, if in just a few weeks it stops working, doesn't seem a big help.
    I use another product to help black plastics to keep in better condition, with deeper black and also avoid the sticky plastic. This also helps belts:
  14. stuck-in-time
    Jakarta, Indonesia
    A few weeks seems a long way off forever >.< I'll try to look for alternatives to that, perhaps. I do think that the automotive guys can help us a lot on terms of cleaning/restoring plastic. And yes, being not in the states/Europe does means that I can never find all those suggested brands in forums.
    As for retrobrighting in general, has anybody tried using liquid hydrogen peroxide instead? That's easily & cheaply available here.
  15. walkman archive
    Yes. liquid can be used too. The 8-bit guy has a video comparing several methods for retrobrighting and the liquid works great too, but the water has to be warmed up previously.
    Seems that for big parts, like a computer case it leaves no 'marks' as the cream can do, due to the way the sun creates 'shadows' depending on how uniformly distributed the cream is.
    That looks like the same type of product walkman archive. I use it on chrome truck bumpers with plastic padding or steps, it goes from being cruddy to nice and black but after time out in the hot sun it tends to need retreatment after a few weeks. I don't know if it lasts longer if it's left inside.
  17. audiodiplomat
    audiodiplomat New Member
    United Kingdom
    Could members in different regions give information about chemicals successfully used by them? For example, I’m in the UK and can’t really obtain Saloncare readily except via import at great expense, and we have a sunshine deficit at this time of year, meaning the undoubted use of uv lamps (?) I’m looking forward to renovating an otherwise pristine “white” Sony shower radio/cdp which looks like it’s been dipped in primrose paint. My wife suggests I use her
    “Steriliq” kitchen sterilizer fluid, but I think it’s far too runny to use. YouTube just has US-centric stuff....and sunshine!
  18. Longman
    There are numerous articles about this. As Walkman Archive has already said the main active ingredient required is Hydrogen Peroxide.
    Some people suggest adding a small amount of Vanish fabric stain remover.
    I guess the main advantage of hair products is that they are designed to form a cream that will stay on the Hair / Plastic.
    Hydrogen peroxide is like water so will just run off.
    A good start might be to look in the hair section of your local supermarket / chemist and look for the lightest blonde hair colour cream.
  19. walkman archive
    Well, I'm in Spain, not in the US. I went to a near hair products store for professionals and asked the woman for hydrogen peroxide cream, which is called "agua oxigenada" cream here. Agua = water, Oxigenada = 'oxygened'.
    I'm totally sure that you can find a similar product near you; no need to find the same exact one.
  20. Virgil Gheorghiu
    Virgil Gheorghiu Member
    Bay Area
    Great results, @hugo @walkman archive!
    I've used this method for some years now on anything from vintage Lego bricks (transparent or white), to walkman gears, reel-to-reel reels and cases, or even full case enclosures / computer parts.
    My favorite is Salon Care™ 40% volume, the red one in the video you posted. It's mild and there are no side effects I could detect. A big ziplock bag and a brush is all you need.
    The reels and cases in the pictures below were all treated and look really, like new.
    There are also boiling/heating methods, but for at least @Jorge and me, sun is free in California :).
    Virgil
    Screen Shot 2019-11-20 at 12.03.18.png IMG_0808.jpeg e167ce189c50b51dd4c79597b1cb5cf0.jpeg
