My Toshiba cassette player collection
Discussion in 'Gallery' started by kent, Mar 3, 2019.
  1. kent
    kent Active Member
    CHINA
  2. Boodokhan
    Beautiful collection.
    thanks for sharing.
    Thanks for showing the boxes, those are always cool to check out, it's too bad they went to the personality-less plastic blister pack in later years.
  4. Chestnut
    Chestnut Member
    Cambridge UK
    That’s quite an amazing collection. As you have so many of the Toshiba variants, you might be able to help as I have a brand new KT-SV1, just purchased. I’ve changed the belt and all was fine until I pressed rewind, which was noisy and I have now discovered the reason: the tiny gear connected to and situated under the spindle has a split in it, so it is fractionally oversize now, hence the noise. It’s the gear that engages with the main drive when rewind is pressed (hence pressing down the rewind spindle and aligns the gears), so I’m looking for a replacement. I guess realistically my only option is to buy another unit, but in ‘spares or repair’ condition and hope the relevant gear is ok within it. As such I wondered if the KT-SV1 mechanical assembly is the same for any other models - any idea? Equally if you have an alternative suggestion on how to get a new gear, or whether the one I have could be repaired, happy to hear about that. If you or anyone else reading this can offer any help, I’d be very grateful.
  5. kent
    kent Active Member
    CHINA
    Hi there,
    Most of my collections have not been repaired because I have more than one thousand sets of cassettes player and the workload will be too big,so I don't know much about maintenance.I think may be I can help you to ask others.By the way ,could you please confirm that the model you referring to is KT-SV1 instead of KT-VS1?
  6. Chestnut
    Chestnut Member
    Cambridge UK
    Thanks. Yes, it’s a KT-VS1 in blue.
  7. Boodokhan
    This is one of the major issues of Toshiba Walkman units. The crack that affecting the spindles comes in 2 different forms. I have dealt with this issue A LOT !!!
    The mechanism is common in many Toshiba walkmans
    You can open a new topic if you like since i do not want to ruin this beautiful topic.
  8. Radio Raheem
    some of these look much nicer than what sony made, just wow
    Walkgirl likes this.
  9. Timewarp
    Timewarp Well-Known Member
    The Netherlands
    Hi Kent, impressive again. Toshiba made some really nice ones indeed.
    You mention >1000pcs, are they all boxed? That would be crazy and super unique.
    Are you ever thinking about showing a part of your collection to the public by temporarily exposing them in a museum?
  10. Cassette2go
    Yes, he did make a museum and a posting of it somewhere and there's a bunch of pictures of that but I don't know the thread. Just drilled down on his name and you'll find it
