No more electricity on wm dd2
Discussion in 'Tech talk' started by walktowalk, Apr 26, 2020.
  1. walktowalk
    walktowalk New Member
    san diego
    hi while putting my dd2 back together
    i lost the red light coming on and any electricity,
    i did get some shorting going on near the dc plug,
    and it got warm.
    so if anyone has some advice about where to look for electricity that would help
    thanks in advance
  2. walktowalk
    san diego
    I think i have a short now,
    when i plugg the battery in it gets real hot
    Open it back up and post photos, it could be a lot of things, I'd check for any wires that may have gotten pinched during re-assembly.
  4. tomtom87
    tomtom87 Active Member
    netherlands
    It is beyond repair i think...
    If you looking for a replacement pcb i have them for sale. And next time use a laboratorium power supply.
  5. Silverera
    Silverera Active Member
    MEL
    Agree with @Mister X and it is likely a pinched wire during reassembly has lost some insulation and is making contact with the solder trails on the PCB. Check the wires out of the battery bay. I have had these short on a DDIII from battery corrosion. Actually melted the plastic housing but did not damage components.
    Also check around that external DC in port that it is not shorting. It may be that and as soon as you put in the batteries there is a dead short across that port.
  6. frblaze
    frblaze New Member
    Paris France
    Salut l’ami
    Here some photos of the wires that might help you.
    Don’t forget to look at the back of the capstan ring there are 2 wires from FWD/REW contact and they are often pinched by the capstan back screw.
    A la prochaine
  7. frblaze
    frblaze New Member
    Paris France
    I forgot
    Check for bridges between your soldering points.
