Panasonic RQ-S series walkmans - complete step-by-step repair guide
Discussion in 'Tech talk' started by mihokm, Dec 10, 2017.
  1. mihokm
    mihokm Active Member
    Slovakia
  2. Jorge
    @mihokm Great post, Thank You!
    I have a word of caution for those who decide to buy Panasonic as their first Walkman repair effort. Until Marian makes new pinchrollers available, double-check that they are in good condition. If Panasonic was left in Play position, pinchroller is ruined. In my case of RQ-SX15 one pinchroller had 0.5mm of its width shaved-off. Ordering RQ-S15 as a donor I have learned that pinchrollers are slightly different and not interchangeable between RQ-SX and RQ-S models, and number 15 is pretty much meaningless. I downloaded a few dozen photos of Panasonic heads and got even more confused as to which models have interchangeable pinchrollers.
  3. Brandon
    Brandon Member
    Sheffield
    Great Stuff , got a few Panny RQ's to re-belt and service this will be very handy.
  4. mihokm
    Slovakia
    Luckily, Panasonic used only two versions of mechanics - one for RQ-S models and early RQ-SX models, the other one for later RQ-SX models.
    I need to produce two pinch rollers to cover all. The pinch roller core is not simple, it has step-hole inside. I'm not sure if my producer will be able to make them. I'm afraid it will be problem. But i will try to find solution
    Currently I'm finishing second version of pinch rollers for Sony walkmans. They should be ready by the end of this month.
  5. Jorge
    @mihokm thanks for the tip! I guess instead of buying more dead Panasonics I will wait for new pinchrollers :)
    I think pinchroller cores should not be a problem, they stay intact and it is pretty easy to re-use them.
  6. walkman archive
