Panasonic RQ S15 that forget's tape is inside and won't play
Discussion in 'Tech talk' started by Raul, Oct 24, 2021.
  1. Raul
    Raul Active Member
    Szczecin
    One Panasonic RQ S15 that I repaired forget's tape is inside and won't play.
    It goes like this:
    I put tape in, play it, it plays one song or songs on both sides with autoreverse. Then when I leave it for some time (could be 5 minutes, could be hours) and when I come back and push play it shows light operate but after a second it just stops. Funny is that it has no problem with rewind or fast forward tape.
    Only way I can continue playing is opening door with casette at least that it goes out and doesn't contact tape selector. Then I close the door and Panasonic 'resets' operation and I can again play it.
    I have seen situatios when tape selector doesn't work at all, but this is strange.
    And I'm not sure it's tape selector problem. Maybe it goes to sleep state?
    I don't have operation manual for it, only service manual.
  2. Raul
    Raul Active Member
    Szczecin
    I've read manual, but there were nothing about this, so it's most probably a problem with Panasonic.
    By "tape selector" I suppose you mean the tape in switch, which detects a cassette is inserted, no ?
    I would clean that first (Kontakt 60), just to eliminate it as a potential cause. If the problem is still there, at least you know for sure that's not the cause.
    Spray some cleaner into it and push it about 20-30 times to be very sure the cleaner has done its job.
    Raul likes this.
  4. Raul
    Raul Active Member
    Szczecin
    I will try to clean it and get back.
