Panasonic RQ-S35 versions
Discussion in 'Chat Area' started by Raul, Feb 24, 2022.
  1. Raul
    Raul Active Member
    Szczecin
    I thought there are 2 versions of this Panasonic, older one with "Silent Mechanism" written on the door, and bigger font "Silent Mechanism" and smaller "Twin Motor Rotor" inside.
    And never one with "Twin Motor Rotor" written on the door and inside, without "Silent Mechanism" written at all.
    But there is maybe* a 3rd version (probably between both, that would make it 2nd one) with "Twin Motor Rotor" written on the door and bigger font "Silent Mechanism" and smaller "Twin Motor Rotor" inside.
    * maybe - there is possibility that door was changed by technican, but I've seen pictures of 3 of them - one I have - that would make it unlikely.
    i-img1198x898-1643703547tqn5y2209141.jpg i-img1200x900-1625996644lwnvmv244448.jpg i-img900x1200-16452681510fyk1q72460.jpg
    Do you have both versions ? Is there any difference inside ? (at least on the visible part of PCB)
    I have never seen the one with "Silent Mechanism" written before, but the other one I have seen many times.
    At first glance, they look the same apart from the markings, but there may be other differences.
  3. Raul
    Raul Active Member
    Szczecin
    The back cover is slightly different, has indent in the down right corner. I know that some versions of Panasonics had the D letter (S1 and S1D) or slightly different motherboard parts (S15 and S15 II, i'm not sure if it was called D).
    Can't find service or user manual for S35, so I don't know for sure if it has any different parts too.
    Maybe Panasonic cheapened in 1991 (for production) their walkmans too, like Sony since 1988. I can't see a reason to make different version of same walkman if there was no gain.
  4. Handheldgaming
    Handheldgaming Member
    Scotland
    I've got one. Just got it working today. It says "Twin Rotor Motor" on outside and inside. No mention of Silent Mechanism.
    That "Silent Mechanism" is likely a marketing gimmick, as mechanisms on these are mostly identical with very minor differences across the RQ-S generation.
    Only big difference is the carraige with/without pad lifter, but the mechanism chassis itself had few differences: flywheel retainers (some have 2, some 1, some none), slightly different motors.
    Same is true for the "Twin Rotor Motor", which exists in other brands as well, like SONY WM-EX series.
    But SONY doesn't name it that way and builds it slighlty different (glue instead of screws for the coils PCB), but basic principle is identical.
