Problem with TPS-L2 motor
Discussion in 'Tech talk' started by Buleczka, Oct 7, 2020.
  1. Buleczka
    Buleczka New Member
    Poland
    So as in title, i have small problem with motor in my tps l2.
    When walkman is turned on, time to time it squeaks as hell and music is slowing down. It can take 2 up to 20 seconds. After that it works perfectly and after bit of time it appears again.
    I looked at it while it's running and it looks like rotating part is pushed out of rest of motor while its squeaks, so maybe its worn out sleeve?
    Its happening with and without belt on.
    Its appears randomly no matter if i shake it or it's in steady position.
    Is there any source to get new one or used? Best if in EU
    Model number is: MNF-1600F
  2. frblaze
    frblaze New Member
    Paris France
    Hello Buleczka
    If you still searching for this motor I have one, it’s not new but it works well.
    Contact me if you are interested. I live I France.
    Greetings
    Boris
    Buleczka likes this.
  4. autoreverser
    ...just a drop of Balistol
  5. Buleczka
    Buleczka New Member
    Poland
    Lubing doesn't work. I tried that before posting post here.
    jacobsteel and Mister X like this.
  6. stuck-in-time
    Jakarta, Indonesia
    These motors can be relatively easily disassembled if you want. Although that does carry with it some risk. The wires to FG coil are very thin and delicate. An alternative would be to take a donor motor from some much cheaper units. Some Sony cassette/micro-cassette recorders use the same motor.
    jacobsteel likes this.
  7. Talkman
    Talkman New Member
    Michigan
    I wouldn't take it apart unless absolutely necessary, if it's operational. My WM-3 had a similar intermittent squealing noise, but I was able to dissolve whatever was gunking it up by putting the motor in a shot glass (enough to cover the part where the rubber band attaches) with some rubbing alcohol for a day. Every few hours, I would twist it lightly with a pair of pliers and feel where the resistance was. Eventually, it freed up and quit squealing. It might take a few sessions of this.
    stuck-in-time and jacobsteel like this.
  8. stuck-in-time
    Jakarta, Indonesia
    Yes I agree. Only take them apart if you have tried everything else.
    Talkman likes this.
  9. Buleczka
    Buleczka New Member
    Poland
    Atm i ordered replacement one from one of users. After replacing it im gonna send broken one to somebody is repairing this sort of stuff, maybe it's fixable.
