Sanyo MGP600D belt path
Discussion in 'Tech talk' started by Longman, Nov 12, 2017.
  1. Longman
    ianthepostie asked for some pictures of inside the Sanyo MGP600D so here they are.
    Years of sunlight have aged this one badly. The back is the colour it all was
    when I got it.
    I like the pattern inside the cassette compartment which is so 80s.
    This was my main personal stereo throughout the 1990s. As described before
    I bought it at an Amateur Radio Rally as a faulty customer return. The only fault
    was that the metal shield on the right had moved and stuck itself on the pulley.
    Before the days of Ebay you used to get companies bringing loads (sometimes literally
    a lorry load) of stuff like this to Radio rallies to offload as spares or repair.
    Annoyingly you never got the battery cover. I presume that was some arrangement
    with the manufacturers to stop people selling them as new after repairing them.
    Belt change is incredibly easy for this one. Just unscrew the back and the belt
    is right in front of you waiting to be changed.
    It is a standard cassette recorder type belt (1mm?) rather than being one of the ultra thin ones used in later
    personals stereos. Annoyingly I didn't have one the right size so have ordered a pack of mixed sizes.
    ianthepostie and 16s like this.
  2. 16s
    16s Member
    I had one of those when i was a kid, your post just reminded me. I remember i purchased a better set of head phones because the sanyo "turbo" ones couldn't handle the unit's bass output and would distort. My unit was 80's pink! After a year or 2 i replaced it with a Panasonic RQ JA-160....lovely :thumbsup:
  3. Longman
    I found a nice picture of the two (Pink and Blue)
    https://www.google.co.uk/search?q=sanyo+mg-600d&tbm=isch&source=iu&pf=m&ictx=1&fir=2yIeNy9tpDdPTM%3A%2COAQb-unlHmXVfM%2C_&usg=__NKXBr4yMGCTXYNqX6MhAMd0P_L0=&sa=X&ved=0ahUKEwjakor6urzXAhXDLMAKHUSlDvAQ9QEINjAD#imgrc=pXqNVNjs-CoJ6M:&spf=1510607372297
    Part of an interesting Blog about Graphic Equalizers on Personal Stereos
    Update - Norton keeps finding something fishy on the site (which is otherwise very good).
    View at your own risk.
    https://personalhifiblog.blogspot.co.uk/2009/
    16s likes this.
  4. ianthepostie
    ianthepostie Active Member
    kent
    Wow! Thank you Longman, you are a star! I have just ordered a set of mixed belts so hopefully I will be able to swap the old one out and hopefully cure the horrendous wow & flutter mine has. Will keep you posted!
  5. ianthepostie
    kent
    Yep, my Malwarebytes just went into meltdown when I clicked that link!
  6. 16s
    16s Member
    GREAT site!!!!
  7. ianthepostie
    kent
    Well, after much trial and error with different belt sizes, I found one that sort of works. The tape now plays at the correct speed and the W&F has gone, but the rewind/FF are really slow. I guess the belt size is still a bit off but at least it plays nicely now.
  8. mankamaz
    mankamaz Administrator Staff Member
    madrid,. spain
    Hi folks
    I also have a MGP600D, frontal.jpg mine is dark blue I also have another Sanyo with the same mechanic, a red MGP33 very similar to the MGP600D but without Dolby
