Sony Walkman WM-DD10 problem.
Discussion in 'Tech talk' started by Dawiddawid, Mar 1, 2018.
  1. Dawiddawid
    Dawiddawid New Member
    Poland
    Hello.
    Recently i found Sony Walkman WM-DD10.
    After dissasembly, i soldered some loose cables.
    All capacitors look ok, no leaks.
    Eeverything looks ok but it isn't functioning correctly.
    I made short video to demonstrate problem.
    Thanks for any help.
    Video:
  2. Dawiddawid
    Poland
    Edit: Sorry for missclick, should be in Walkman tech forum. Please relocate this.
  3. bub
    bub Active Member
    I can't really tell what's going on- is the capstan flywheel too slow? If it is, try to rule out mechanical problems first (like excessive friction from flywheel thrust setting).
    If mechanical is ruled out, there's a chance bad capacitors is affecting the motor drive circuit. Sometimes the capacitors fail by drying out rather than leaking (which is supposed to be the "correct" failure mode...)
    Check if FG wires/coil are ok, if the Walkman has them. Check if the capstan flywheel tire is ok, and not melted/dented. Add 1 drop of sewing machine/low weight motor oil to the motor bearing, if it seems the motor is bogging down.
  4. Dawiddawid
    Poland
    Hello.
    This part is FG coil? What is full name, and how i can check corectness of operation of this part?
    Photo of part [​IMG]
