Sony WM-10/20 User
Discussion in 'Introducing myself' started by jmDc, May 16, 2017.
  1. jmDc
    jmDc New Member
    philippines
    hello i'm jmDc and i started collecting sony wm-10 and wm-20 because they are small and i like portable stuffs. i want to replace the belts of some of my wm-10/20 but i don't know how to open them any help will be greatly appreciated. thank you.
  2. Boodokhan
    Hello jmDc
    Welcome to the forum. Please use the service manual that I will upload here in next post. If you need the appropriate belt this is the link to get the exact size belt
    http://www.ebay.com/itm/Walkman-bel...186239?hash=item1e918141ff:g:eF4AAOxyrrpThOEP
    Let me know if you need further help. Changing belt on this Walkman is not difficult. Sometimes you need to clean the goo of melted original belt. Make sure you clean it good
  3. jmDc
    jmDc New Member
    philippines
    great! will wait for the service manual that you will upload and check the link for the belt.
    thank you so much :hi
  4. bronco
    bronco Active Member
    Spain
    :)Welcome to the forum, and good luck with the task!
  5. Boodokhan
    Let me know if you need help and I will open one of my Wm-20 to show you How to do it
  6. jmDc
    jmDc New Member
    philippines
    thank you :wave:
  7. jmDc
    jmDc New Member
    philippines
    thanks so much :) downloading... :reelspin:
  8. jmDc
    jmDc New Member
    philippines
    hi i was able to download the attached troubleshooting guide file (thank you) but can't find in there the disassembly procedure. yes, can you show me how to open please? thanks again.
  9. Boodokhan
    I will open a Wm-20 tomorrow evening , will place pictures and simple marking to show it in a simple way
  10. jmDc
    jmDc New Member
    philippines
    many thanks :hi
  11. Helaba
    Helaba Active Member
    Belgium
    Another Angel came down to earth!! :) you are just fantastic!
  12. Mystic Traveller
    Welcome, jmDc! :wavey:
  13. Boodokhan
    East steps to change belts on your WM-20.
    You need a tweezer and a small screw driver and obviously appropriate size belt
  14. Boodokhan
    First pull down the face plastered and open the two screw shown in the red box and gently remove the face plate
  15. Boodokhan
    Make sure the tape button is switched to "Normal" and Dolby is switched to "off"
    ( this is important when you are placing the internal parts inside the back plate)
  16. Boodokhan
    Open the four screws that marked with green circle
  17. Boodokhan
    By Using a pair of tweezers open the screw that hold the volume control.
  18. Boodokhan
    Now you can remove the back plate. But remember yo be gentle when you are working with your Walkman.
    You can look at the belt that is already installed and follow the same way this one is installed
    Most probably you need to clean the melted belt. So make sure it is well cleaned before installing the belt
  19. Boodokhan
    Is you see a lot of goo around the motor you should remove the plate ( by opening these 3 screws) to have better access to clean
  20. Boodokhan
    I will leave this Walkman open till tomorrow. Let me know if you need additional help.
    Any by the way I am not expert at all. I know very little and I would love to share what I know with other members.
    And by the way, this Walkman won't work if a headphone is not hooked to it. So make sure before opening it it works and you hear the motor running
    turtle561 likes this.
