Sony WM-22 produces a wobbly sound
Discussion in 'Tech talk' started by angorawol, Oct 4, 2017.
  1. angorawol
    angorawol New Member
    Antwerpen, Belgium, Europe
    I bought a mint Sony WM-22. But gives a wobbly sound, does it need a new belt? Strange because it doesn't seem used at all. The sound works (both sides) also the rewind and forward mode works.
    Depending on how the Walkman has been stored the belts could have deterioated evn if has never been used. The belts aren’t that different from rubber bands. I am sure everyone has stored something with a rubber band around it only to find it has lost its elaticity or evn broken a few years later.
  3. buzbox
    buzbox Active Member
    Yep belts and a bit of oil or lubricant on the pulleys or gears can help.
  4. angorawol
    what kind of lubricant is the best?
  5. T-ster
    I use a fine watch oil on my walkmans and boxes, works great.
  6. angorawol
    thanx you guys for your quick tips, helps a lot
  7. buzbox
    I use this at work and home too. Does the job. Many other types out there so shop around. I'd stay away from WD-40 though. Its good for a temporary fix but a good lubricant is best.
  8. angorawol
    thnx Buzbox but I'm afraid that this kind of lube is not available in Belgium, Europe. ;)
  9. buzbox
    Should be able to find something similar
  10. angorawol
    I know, I was just kidding
  11. Longman
    Has anyone tried Sewing Machine Oil? It should be readily available and I have seen it recommended for other mechanisms like model railway engines.
  12. angorawol
    thats what I had in mind, or victorinox oil
