sony wm-r2
Discussion in 'Tech talk' started by stef, Jun 13, 2020.
  1. stef
    stef Member
    milan
    hi
    someone can help me about a problem on wm r2?
    i need service manual because it doesn't record . play ok /switch play- rec ok/ erase ok. you cannot heard recorded voice. you heard like it records in play back but without voice with internal and external microphone.
    hot line????? thank you for answers
  3. stef
    stef Member
    milan
    Hi thank you for your suggestions. I need Wmr2 service manual because I want to follow the record signal and where is bias . It is impossible to find it.i tried 2 cassettes and foam is present.there is a little reduction of sound recording after 1-2 second.i will clean well the switch but it could be some cap.
  4. stef
    stef Member
    milan
    Play goes well an so the head should be in correct position and work . How does it is possible to try if head is in correct record position?
  5. stef
    stef Member
    milan
    It should be bias problem.i found service manual by top walkman technician
