TPS-L2 help
Discussion in 'Tech talk' started by TJRegan, May 8, 2017.
  1. TJRegan
    TJRegan New Member
    Bournemouth
    I've recently purchased a TPS-L2 walkman however I'm having motor issues. When I press play, the motor spins for about 3 seconds, then stops, but if I press it quickly again it will spin for half a second or so. It spins smoothly and at the usual speed but just stops suddenly with no hint of struggle. Once it has stopped, it doesn't attempt to continue spinning even when pushed. The red power button lights up and static can be heard through headphones (I cannot hear music as the drive belts are to be replaced but if the motor isn't functioning that's unrelated really). Also, I tried pressing fast forward and rewind but the motor still spins only in one direction for the same duration of time. Prior to this, the motor would not move at all, so I took it apart and lubricated it. If anyone could help, I would be very grateful. I'm hoping the issue is just the motor and not power related as electrics aren't my strong point... Thanks :D
  2. TJRegan
    TJRegan New Member
    Bournemouth
    Just realised this seems to be the wrong place to post...
  3. T-ster
    Welcome to the site mate, i have moved this to the correct forum in the walkman area where it will get more exposure :)
  4. TJRegan
    TJRegan New Member
    Bournemouth
  5. Boodokhan
    I am not an expert but this is what i would do
    try to run the motor directly with a battery. If it works fine the problem is not the motor
    I am sure other members can recommend you the right steps.
  6. TJRegan
    TJRegan New Member
    Bournemouth
    I'm not sure what connects to where, there are 4 cables going into the motor :/ I'll try work it out though, thanks :D
