Walkman DD11 - recapping and potentiometer repair
Discussion in 'Tech talk' started by jacobsteel, Jan 25, 2022.
  1. jacobsteel
    jacobsteel New Member
    Gothenburg, Sweden
    The Walkman DD11 is one of the last DD Walkmans; one where Sony did away altogether with the large cogwheel (which started breaking even when these machines were still on sale). Pressing play here moves the play-head ass. directly.
    I got my DD11 cheap as it was malfunctioning in several ways:
    1. A loud high pitched whining was heard in operation - changing several large electrolytes amended this. Tricky, but it could be done.
    2. Someone else's previous attempts at speed regulation + repairs had destroyed the circuit board around the speed control potentiometer. The WM DD11 uses - also named IC 601 - a CX20084 for the speed control. Yet, the design here is somewhat simpler than in e.g. the D6C (e.g. no Quartz control as far as I could see).
    I soldered a replacement potentiometer directly to pins 4 and 5 via a resistor, shrink wrapped and glued into place. Speed was adjusted and it now works very well. Just thought I'd post if here for inspiration.
    Recap of a DD11 and potentiometer replacement can be done!
    C83 and Deb64 like this.
  2. Superwhaleman
    Superwhaleman New Member
    Hello and thanks for this post! I'm currently trying to fix my speed potentiometer and if everything fails I might try your solution as well. Is the resistor between the potentiometer and pin 4 the 47k resistor R603?
    Thanks!
    jacobsteel likes this.
  3. jacobsteel
    Gothenburg, Sweden
    Yes! Exactly, as I only had very thick cables at the time I made it like that. Best of luck!
    As I remember it, recapping was hardest...
  4. Superwhaleman
    Thanks for your answer!
    Yes I'm currently also doing the recapping, that's how I damaged the potentiometer in the first place .....
    I hope I get it all running again. Only a three of the small capacitors and the potentiometer are left to do.
    Thank you!
  5. Superwhaleman
    Late update
    I finished the recapping and it works again!
    I also found a fitting potentiometer to replace the broken speed potentiometer. The only problem is the adjustment screw is on the opposite side of where it usually is so if I need to adjust the speed I have to move the main board out of the shell but that's okay since I won't need to adjust it again any time soon hopefully.
    When I put it back together I hadn't noticed that the Chrom/Fe switch had come loose and when i tried to put the shell back on it broke of the little switch ...
    If I want to switch between Chrome/Fe I have to open the shell and use a toothpick now, but luckily I'm not using that switch a lot anyways...
    well...I learned a lot and the main thing is the walkman works again which I'm very happy about.
