Wanted: Mirror cassette for head adjustments
Discussion in 'Gear you want' started by buzbox, Jun 20, 2017.
  1. buzbox
    buzbox Active Member
    Hey all. Looking for a mirror cassette. I have a few cassette decks that need adjusting. Anyone have a spare mirror cassette that they are willing to sell? I'm located in Australia so willing to pay for postage.
    Regards,
    buzbox
  2. Boodokhan
    What is mirror cassette? is it same as speed calibration test cassette?
  3. Jorge
  4. Jorge
    A few years back there was a heated discussion on the usefulness of mirror cassettes here: TAPEHEADS
    Unfortunately, the guy who wanted to offer one with internal illumination got discouraged by the community :(
  5. buzbox
    Can anyone explain why there would be different thicknesses?
  6. bub
    bub Active Member
    You can make one quite easily yourself. Create the tape from a common cassette with a good shell (Most TDK D), and buy the thinnest plastic/mylar mirror sheet you could find that provides a clean reflection and is thick enough to hold its shape well. (I used leftover mirror sheet from a Tamiya display case).
    Next, snap/cut off the area on the head/capstan/pinch roller of Side A making sure that all the pins that guide the tape are on Side B and are intact. Insert and glue tiny squares of mirror sheet at a 45 degree angle to the tape surface- you may need to modify the shell a little to do so.
    That's it! You can also cut out 1 long rectangle like those Abex/Teacs, but you'll need to modify the shell even more.
    With different tape thickness, you can look for skew in machines more sensitive to certain types of tape- I have a Panasonic that only skews on one model of tape, for example.
