WM-D3 weird wow/flutter issue...
Discussion in 'Tech talk' started by subcode, Apr 15, 2019.
  1. subcode
    subcode New Member
    Greece
    After I replaced centre gear, capstan flywheel rubber, rewind gear and counter belt that i bought from marian i decided to check wow/flutter...
    The gear installed and lithium grease applied to gears.
    I did the measurement using a speed test tape with 3Khz test tone i also bought from marian while adjusting the screw above the flywheel. When the lowest w&f achieved i apply screw locking compound.
    The measurement is below:
    Average w&f measured about 0,05% which is good.
    So i put everything back and i connected my D3 to my home stereo to record a mix tape...It records and plays beautiful except for one weird thing...
    On some tracks and on specific frequencies (mid/hi frequencies) i hear "flutter"
    One example is the first seconds of Under the bridge by Red hot chilli peppers. The high-tone guitar sounds like there is no speed stability...
    Audio Sample:
    https://1drv.ms/u/s!Ao5Bf-pif9F3gQgE04od7MapDx1r?e=93xZuj
    When i try to record the same song on another cassette deck with worse wow & flutter (0.07) i cannot hear flutter or it is barely audible...how is this possible???
    The interesting thing is that the measurement of the other cassette deck (TC-KE600S) is more stable...it varies from 0.06 to 0.07. The D3 measurement varies from 0.03 to 0.07
    Of course i used the same tape on both machines...
    Any ideas???
  2. megott
    megott New Member
    Eger, Hungary
    Please check it the little washer under the capstan shaft!
