WM-DC2 Developed noise
Discussion in 'Tech talk' started by David O, Jun 5, 2018.
  1. David O
    David O New Member
    Uk
    My trusty wm-dc2 has developed noise on the right hand channel. This is only on the headphone output and can't be heard on the line out. If you press play (without a tape in) and the volume is above 3 it is very prominent.
    Is this a known problem and is it an easy fix? Doe the headphone op amp need replacing? Is this a repair for the experts?
    Thanks
  2. T-ster
    I would say this is most likely a failing capacitor so it will need that switching, as these fail they tend to introduce noise. I had a walkman doing this, a low end Sony one and I replaced the suspect caps and it was fine.
