CX20084 current draw
Discussion in 'Tech talk' started by dotneck335, Jul 26, 2024.
  1. dotneck335
    dotneck335 Active Member
    Los Angeles, CA
    Yes. There's a LOT to be said for the old adage:
    "If it WORKS, don't FIX it!!!!!!"
  2. dotneck335
    Los Angeles, CA
    Valentin: "In regard to the diode I attached a picture. The simplest way I see is remove that jumper wire and add the diode there (it may require enlarging the holes).
    Then you only need to cut 1 trace and reconnect the rest of the circuit after the diode."
    What I would propose is to cut that trace which leads to the jumper wire just where it joins down from the external power jack and move that reverse-polarity diode to that break---that way it protects BOTH the battery and external power supplies from reverse voltage. Then put the 4 volt regulator in place of the jumper wire.
