Gold Star TSR 800 belt
Discussion in 'Tech talk' started by Algis, Mar 6, 2026.
  1. Algis
    Algis New Member
    Lithuania
    Hello everyone.
    I bought this device. Can someone please provide the belt dimensions?
    It is very difficult to get the correct value when measuring the old ones. It is not clear how much they are stretched.
    The same is also the Prosonic PQR 9962
  3. Algis
    Algis New Member
    Lithuania
    I've seen this too. It's very expensive for me in Europe. There are sellers in Europe, but you need dimensions. You'll have to experiment and order several dimensions for one belt.
  4. vintagerestore87
    vintagerestore87 New Member
    EUW
    Hi, I don’t know that particular model, but you could try WebSpareParts (www.webspareparts.com). They’re based in Europe and I usually buy belts from them. Some time ago I needed belts for a Luxman and they didn’t have the model listed in their shop, but they managed to sort out the two belts for me.
  5. Algis
    Algis New Member
    Lithuania
    vintagerestore87 Thanks. I know them, I ordered a few there, maybe some of them will fit.
  6. Algis
    Algis New Member
    Lithuania
    maybe someone needs it
    diameter 32 mm,0.85 mm thick
    diameter 31 mm,1.2 mm thick
    diameter 39.5 mm,1.0 mm thick
    diameter 37.5 mm,1.0 mm thick
    diameter 57 mm,flat 4x0.55 mm thick
