HS-PX505 Mk II play/stop problem
Discussion in 'Tech talk' started by Michelle Knight, Nov 17, 2026 at 8:40 AM.
  1. Michelle Knight
    Michelle Knight Active Member
    Sussex, UK
    Sorry I haven't been around. Life is a four lettered word as they say.
    Anyway, I've got a number of HS-PX505 Mk II units which have fallen foul of the play/stop button problem.
    I've read a number of threads about it and I've got my main unit on the bench and I thought I'd double check with precisely what I need to do, before I wreck things further than I need.
    I have checked the play/stop contacts and also the two pins which appear to be between them, and I've got continuity across them all. So this isn't a case of permanently bridging a couple of pins.
    If I read correctly, it's the microswitch which is between the stop and play buttons, and my mind is saying, because I've got continuity, I need to remove the microswitch... but obviously that's destructive and I should check with people who have done it... before I do anything.
    I'd be grateful for advice on how to proceed please.
