Massive W&F After Replacing Rubber Tires
Discussion in 'Tech talk' started by Capturing Memories, Nov 1, 2026.
  1. Capturing Memories
    Capturing Memories Member
    After replacing all 3 rubber tires from this trusted seller I got a horrible wow and flutter, I haven't replaced the pinch roller yet but it worked fine after replacing the belts and prior to replacing the rubber tires, I may have to put the old tires back on but before I do that any other reason that may cause this problem? I'm really disappointed.
    With the PCB flipped out, I fiddled with the motor while the tape is playing by pushing it down or lifting it up to no avail.
    I also would like to point out that W&F worsen when the take up spool is full and sometimes stops and tape gets eaten before it goes to auto stop.
  2. Steve Grant
    Steve Grant Active Member
    Vancouver British Columbia
    If the rubber pinch rollers are larger than the originals, they could be rubbing against something.
  3. Capturing Memories
    They can't be larger, they have to fit in their groove.
  4. Steve Grant
    I don't know about yours, but on many players the assembly including the rollers moves when Play is engaged, so the rollers need clearance for that repositioning.
  5. Capturing Memories
    No, these are identical to the original parts. Besides, I did not replace the pinch roller just the idler tires.
    What are the W&F figures before/after ?
    Used these rubber tires and capstan ring for a long time and didn't have problems with it.
    Is there any visible wobblying of the rubber when running ?
    DutchNick likes this.
  7. Capturing Memories
    I did not measure the W$F before, but now it's audible, something is wrong but I don't know what it is, I will try to take a video next time with the PCB flipped out.
  8. DutchNick
    DutchNick Active Member
    United Kingdom
    It needs asking: are the tires round? I don't know how much deviation from perfectly-round is permitted but I'd guess "not much".
  9. Capturing Memories
    They look fine and they don't wobble when they are spinning.
  10. Squiggly
    Squiggly Active Member
    Texas
    id guess something overlooked when installing them or needing to re-align or calibrate it, whenever i have issues after using reputable parts i first assume i missed something than assuming the replacements are the problem
    could try checking motor alignment and the thrust bearing if you havent already, else maybe with the symptoms in mind you could go back over the installation and see if there wasnt something minor that went overlooked
  11. Steve Grant
    Can you try a different cassette? A cassette I have been using for testing for years has become "sticky", as cassettes do, and resulted in a lot of unnecessary work on belts, motors etc.
  12. Capturing Memories
    I tried a lot of cassettes, some are better, some are worse but they all exhibit audible W&F, I will take it apart again and do a thorough inspection.
  13. Valentin
    Does it exhibit the same W&F regardless of speed tune being set to on or off ?
  14. Capturing Memories
    Flipping the switch on or off does not make any change other than change speed if the knob is off center.
  15. Valentin
    Turning the speed tune on disables the quartz lock (PLL), so it's more than just a speed change.
  16. Capturing Memories
    Then I don't understand your previous question. I'm fully aware what the switch does, but it is not the root cause of the problem, if it is it will go away when I turn the switch off, hope I'm clear.
  17. Valentin
    Point is an incorrect adjustment of the RV601 can make the PLL loop unstable and create high W&F.
    When that is the case, the high W&F will go away when speed tune is set to ON, as the PLL is no longer connected.
    Was just something to check, as that trimpot cursor can be moved accidentally or it may have been close to the limit before.
  18. Capturing Memories
