My TDK Cassettes Collection
Discussion in 'Cassettes' started by soluna, Mar 16, 2023.
  1. Black Fingers
    Black Fingers Active Member
    yeah getting one from ebay is easy if you want to spend top dollar, i'm tempted to get a Maverick of the bay...but the original Audua is rare as it is and i found one that meets my criteria, tabs intact, clean j-card and preferrably with clean sticker sheet. And the nice thing about buying used cassettes is that there is music on them or that i never heard of, or it's something i like so then i will keep it....have some nice Jimi cassettes now, also an album by Talk Talk that i didn't had.
    If i don''t like the recording they will go through the Weircliffe bulk eraser and the tape is fresh again. And since i also buy bulk cassette lots, all the doubles i have will go on sale so i can buy some more TDK that i don't yet have. :)
    And will have to see if to Ikea frames are still available, maybe some will turn up in the thriftstores here....
  2. soluna
    soluna Well-Known Member
    Interesting device, this weircliffe - how does it work ? Only putting the cassette in the slot, and push the button ? I can`t imagine, that really the whole tape is erased completely.
  3. Black Fingers
    well this Weircliffe Model 6 was a standard device that you could find in pro recording studios back in the 60's, 70's, 80's and still used today by me and was designed to erase reel to reel tape, in this model 6 inch tape are the max....there is also a Model 8 and even a model 10 or 12........
    But bying new tape back then was to expensive so to degauss it they had a bulk tape eraser like the Weircliffe.
    As you might know when you put current on a transformer coil (or any copper coil) a magnetic field is created within the center of the trafo coil, this is the way solenoids work for example.
    So this magnet, which in this device measures approx 30cm x 25cm, which is huge, is then cut in half to release the magnetic field and you have a bulk tape eraser. You can even build yourself one, search on google for diy bulk tape eraser but be aware you're working with LETHAL voltages!
    So this magnetic field randomizes all the ferro/chrome/metal particles on the tape to zero/bias state which basicly means you have new tape.
    No more shadow copies to be heard what sometimes happens when you record over an old recording and the deck you recorded on has not enough Gauss to erase the tape.
    For example take this page http://vintagecassettes.com/tdk/tdk_files/tdk_type/tdk_ma.htm
    TDK MA
    Magnetic Particle: Finavix
    Coercivity: 1130 Oe
    Remanence: 3200 Gauss
    Squareness Ratio: 0.84
    You can see coercivity is 1130 Oersted and remanence is 3200 Gauss (which is high), if the current of the erase head isn't high enough the tape will ot be fully erased.
    This Weircliffe easily erases ferro,chrome and metal cassettes. Also has no problem fully erasing DAT tapes, wipes them totally clean including all indexes....
    But read this on wikipedia
    Degaussing, or deperming, is the process of decreasing or eliminating a remnant magnetic field. It is named after the gauss, a unit of magnetism, which in turn was named after Carl Friedrich Gauss. Due to magnetic hysteresis, it is generally not possible to reduce a magnetic field completely to zero, so degaussing typically induces a very small "known" field referred to as bias. Degaussing was originally applied to reduce ships' magnetic signatures during World War II. Degaussing is also used to reduce magnetic fields in tape recorders and cathode-ray tube displays, and to destroy data held on magnetic storage.
    and...
    Data is stored in the magnetic media, such as hard drives, floppy disks, and magnetic tape, by making very small areas called magnetic domains change their magnetic alignment to be in the direction of an applied magnetic field. This phenomenon occurs in much the same way a compass needle points in the direction of the Earth's magnetic field. Degaussing, commonly called erasure, leaves the domains in random patterns with no preference to orientation, thereby rendering previous data unrecoverable. There are some domains whose magnetic alignment is not randomized after degaussing. The information these domains represent is commonly called magnetic remanence or remanent magnetization. Proper degaussing will ensure there is insufficient magnetic remanence to reconstruct the data.[7]
    Erasure via degaussing may be accomplished in two ways: in AC erasure, the medium is degaussed by applying an alternating field that is reduced in amplitude over time from an initial high value (i.e., AC powered); in DC erasure, the medium is saturated by applying a unidirectional field (i.e., DC powered or by employing a permanent magnet). A degausser is a device that can generate a magnetic field for degaussing magnetic storage media.[8] The magnetic field needed for degaussing magnetic data storage media is a powerful one that normal magnets cannot easily achieve and maintain.[9][10]
    So yes it completly erases all data that is on any magnetic layer....on the Weircliffe is a warning that people who have a pacemaker cant use this machine...also bank cards and wrist watches need to stay far away or they will be damaged.....
    And ofcourse i check every cassette after ive put them through the eraser if it was properly erased. Basicly you press the the slot cover down, this activates the trafo, slide your cassette in en out and it is done...like 5 seconds work....metal tapes like MA take two slides and need to be exposed a bit longer then ferro tape......
    Last few weeks ive succesfully degaussed more then 300 cassettes all ready for new recordings.
    Does this help?
  4. soluna
    Very detailed explanation - thank you. I only had the basic knowledge. It`s not easy to get one with the europian 230 V - standard.
  5. Black Fingers
    yeah i was looking for one for many years. They do popup on ebay but shipping from US or AUS is not viable (thing weighs about 25-30kg) and those run on 110V....
    but i was lucky to find one in NL only 45 minutes drive from my house. It came from an estate clearance.
    And Weircliffe is/was an English company so that i have an 'export 220V' one is special.
  6. Black Fingers
    @soluna
    Couldn't tell if you have this set already, 4 pack TDK D60 Limited Edition Color. I know you prefer 90 min but these are quit rare.
    https://www.marktplaats.nl/v/cd-s-e.../m2395069484-tdk-limited-edition-color-sealed
    Yesterday received this in the mail, complete and clean set in original box. Don't know if the cassettes in the box are in a wrapper when bought new but i suppose so.
    This version does not appear yet on 45cat, i've checked, i've registred and i'm adding my cassette collection.
    Cassettes have 'Made In Japan' but j-card only has two adresses on the back. Both EU versions with MIJ have three adresses on the j-card. Other version only has 'Japan' on cassette and that j-card has two adresses. TDK really mixed it up!
  7. soluna
    These Color Edition i have with 90 minutes in the collection . There is existing a 5 Mix Colour Limited Edition with the same D like in the link but an additional orange cassette - this i would need. You can find it on the second picture down on the shelf here https://stereo2go.com/forums/threads/my-tdk-cassettes-collection.8611/page-8#post-91432
    And this D90 from `82 i also have single sealed.
    and i have two other versions of the 82 D for the Europian region. By the way - the 82 D was the cassette with the most different declarations of the back side - i have 12 .
  8. Black Fingers
    lol 12 different 82 D ones? Luckely i collect used ones :p
    But do you have this set of Freddie Land complete already? Still no one knows where they came from.....
    Just did some research on Chewie Newgett Company. They created the cartoon figure Freddy Pengiun and it was drawn by illustrator/artist Stewart Moskowitz.
    The Chewie Newgett Company was license company so they licensed their work in co operation with for instance TDK but also Dakin which made pluche animals from them. I think they changed the 'Y' in Freddy for 'IE' for JP market, looks to much like a kanji ;)
    Here a Freddy Pengiun pin on Etsy
    https://www.etsy.com/nl/listing/533571997/freddy-penguin-met-ballonnen-broche
    edit: seems mr. Moskowitz passed away in 2017 and the rights to Freddy Pengiun belong to Disney now.
  9. soluna
    Thanx for the info, and yes - TDK never had taken kanjii pics for there merchandise ))).
    The Freddie Collection is completed - it`s in the middle from big rack.
    And yes - in 82 for example there was edited a D including Australia - this was built in Korean Republik
    and the special Japan Edition
  10. Black Fingers
    Ah the reliable cassette :)
    Yesterday scored this one, TDK AH-202
    Crack in the case doesn't bother me, have a decent one here.
    In the ad it shows it is working but if i will use it is another thing.
    Also scored my 1st Freddie Land cassette (3 Pengiuns Yellow), still sealed for €15,-.
    And do you know anything about this cassette? Apparantly TDS is the predecessor of TDK according to this site https://gobatools.net/items/69a94c003e68ea08a1cc2c3a (Japanese use translate)
    Quote: This is an early "LOW-NOISE" model released in 1971 by TDK, a top brand of cassette tapes. The packaging is of high historical value, featuring the old "TDS" logo design and geometric "CASSETTE" typography in the background, which can no longer be seen today.
    Can't find anything about T.D.S. but they made atleast 2 different cassettes.....thinking about getting that other TDS from that JP site, they also have them sealed ;)
    This red/black C-60 is on its way to me. Great design!
  11. Machaneus
    Machaneus Well-Known Member
    Athens
    Very interesting, never heard of TDS but on the links ad 6th picture showing the back of the cassettes is different and in Japanese with a 3M logo is it related with TDS or it's just a sellers mistake ?
    ... Google lens translated :
    Mister X and Black Fingers like this.
  12. soluna
    @ Black Fingers I have an AH-201, also with a crack in the case . I still need an AH-202.
    Your AH-202 looks exactly like the HD-01, here you can see pictures at ebay https://www.ebay.de/itm/168195475308 . But in the original HD-01 - Blister there is another cassette
    HD-01 blistered (1).jpg and here`s another HD-01, i have HD-01 (1).jpg but in this case there is still another cassette
    HD-01 Eraser (3).jpg And this cassette is the same like in my AH-201. Tohubawohu...
    and also @Machaneus
    I think, the TDS - Story is nonsense - why TDK should offer a TDS - Cassette and renounce a world-known branding with the well memorable crystal - LOGO ? By my meaning the story ( and even the branding ) only is to hype the tapes. By the way - there is another brand, TOK, they have sold TDK - lookalike merchandise stuff. I for example have a pencil eraser in style of a TDK-Cassette.
    20260604_113216.jpg )))
  13. soluna
    Come to think of it, TOK actually constituted a bizarre copyright infringement. They uses exactly similar design and LOGO with this marginally changed name... You really must have a closer view to discover the difference.
  14. Black Fingers
    @soluna i think you're right about TDS not being TDK....
    Because @Machaneus translated it but that cassette is a different one then the TDS, black case has round mark and all other TDS are sealed and show that they are made by Teikoku Denshi Shoji Company LTD.
    Did some research on Teikoku and they have been around since 1936 and are still in business today and are a BIG concern specializes in 'canned pumps'
    Teikoku translated means empire, Denshi =electronics, Shoji means room divider.....lovely
    I think this TDS was a sub company from Teikoku and i also dont think it has anyhting to do with TDK or 3M for that matter...could be that they used the same tape, no one knows.
    Backside of my TDS
  15. Black Fingers
    @soluna
    I think they changed it from 'head eraser' to 'head demagnetizer' for export market, sounds a bit more friendly.
    Only difference i can see between AH-202 and HD-1 is the sticker on the back of the cassette itself. On AH-202 this is in Japanese, on HD-1 in English. Have to see when it arrives but seems to be the same cassette but don't know if there is any difference in the electronics, circuit board looks the same but that doesn't mean it is the same. (in this case probably is)
    edit: both have the same pcb serial 7060 G
  16. Black Fingers
  17. soluna
  18. Black Fingers
    man you've got it all!!! :p
    scored a NIB Fermo 90 min yesterday, can't wait till it's here :)
  19. soluna
    Here now the screenshot from the cassettes i meanwhile have got until June `26.
    only a few of cassettes are new models in the collection, not only cassettes with versions of declaration, or card headers with double packs of tapes, i already have.
    For example the `Music Cassette` and a Head Demagnetizer in Best condition Blister Package. Everytime it`s fine to find some of the `Oldies` - like OD, or KR in good condition sealed to be able to change them with the place holders, i have. But also this time there were no cassettes, i have on my To-look-for-list. And, - But, - there are some, they will come next time. To be conzinued...
    Black Fingers and Mister X like this.
  20. soluna
    Last, but not least - the newest aquisition, i`ve got
    My pink appleanne now has a yellow sister, unfortunally still without inlay card, unsealed, but she has a place as placeholder. The 3 D 90 all have an US deklaration - ( assembled, or Made in US - not easy to find. ( the Double Pack shows two of First Edition D-C90 for North America from `72 in Condition Mint...) And the 3 -X - Card Headers are some of the more valuable ones, got them for a good price. Now there are 683 items in the collection, still about 10 are on their way to me.
    Black Fingers likes this.
