Mystery PCDP: Teac PD-P3
Discussion in 'Discmans, Minidisc, DCC and other players' started by Eryan, Oct 16, 2026.
  1. Eryan
    Eryan Member
    Bavaria, Germany
    Good day gals and gents,
    I just stumbled upon an unusual portable cd player on Ebay. It is a Teac PD-P3. I've spent the last two hours going over old Teac catalogues and I've not been able to find anything about it. all that I could find is that it was sold in Australia.
    The one I mean is being sold with box and manual, and it is in relatively good condition. Asking price is 45€ plus shipping. Any hints towards what it is, or any technical specifications?
    Thanks in advance!
    Mister X and Jorge like this.
  2. Jorge
    what a coincidence – I am reviving its older brother, TEAC PD-P7 right now! That was a pretty humble digital beginning for the company which nowadays makes the best-ever CD drives – in 1990 TEAC just re-branded Toshiba and Panasonic discmans.
    You were right in your other post, PD-P3 is an exact copy of Realistic CD-3250 which is a Toshiba XR-9421:
    Very solid Discman, built like a tank and very decent sounding. As you probably know, I sell revived Discmans on eBay, mostly 1st Gen collectible Discmans, but some ‘budget’ Discmans also worth the efforts of saving. D-33/34/36 and D-321 from Sony, DPC-782/981 from Kenwood, and CD-3250 play way above their ‘pay-grade’! Below is the description I post on eBay when listing CD-3250:
    Exact copy of Toshiba XR-4250 re-branded for Radio Shack as Realistic CD-3250. By 1991 Toshiba had finally stopped making Discmans 'their own way' and designed XR-4250 using Sony parts and Denon layout ideas. One notable exception: only thru-hole parts seen on the mainboard in the age when surface-mount resistors had become a standard. This is as 'old-school' as you could get in 1991...!
    Extra heavy plastic, beautiful matt-grey-metallic finish (thankfully, unlike Denon Discmans it is not rubberized gooey stuff), case is big enough to accept 6xAA batteries which last forever. Hardwired On/Off switch guarantees there is no 'standby' current draining batteries when Discman is turned Off. CD-3250 sounds as good as any 1st Gen Discman, and WAY better than anemic buffered 1-bit cheapness which came a year later. NJM3415 headphone amp outputs 20mW into 32Ohm and drives Sennheiser HD600 without any troubles. KSS-220A laser is one of Sony's best, although not designed to do so CD-3250 plays CD-R discs without any glitches
    Apart from the usual mishap of a damaged CD puck, this model has a nasty habit of being over-susceptible to taps/bumps/vibration. LMK if yours is one of these, it takes exactly two minutes to fix
    Hyperscope, Mister X and Eryan like this.
  3. Eryan
    Eryan Member
    Bavaria, Germany
    Good morning sir!
    This is awesome news! I pulled the trigger on the player yesterday, mainly out of curiosity since I had no clue what it was. Only then I thought about doing a reverse image search, and so I came to the Realistic cd 3250 and to your post.
    The seller sent me a couple of pictures with the specs of the player, but they seem to mismatch what you say about the Realistic. But once the player arrives I'll take a listen and check if the paper specs are really worth discussing. I'll be shipped on monday, so I have a few long waiting days before me.
  4. Eryan
    Eryan Member
    Bavaria, Germany
    Good day!
    The player arrived today, and I am happy to report that it works wonderfully. It is also in mint condition considering that it is 35+ years old. A few light scratches on the window in the lid, but apart from that, everything is clean:
    After unpacking, I put a set of rechargeable NiMH batteries in, and gave it a go. To my dismay, the player had issues reading the CDs and it was really skippy. But then I remembered reading somewhere, that these devices are really sensitive to empty batteries, and that they do not show on display when they are low. The player came with the original AC adapter, but with an Australian connector. But I then also remembered, that my (former) D-99 and my (still non-functional) D-90 also use a 9V adapter with negative center. And low and behold, with a steady power supply, the player sprang to life with absolutely no issues. It reads the TOC immediately, it skips tracks without issues, and the headphone out is powerful. My 32 Ohm headphones are not an issue at all.
    The only problem now is that the seller forgot to send me the manual (it was pictured in the eBay offering). I requested him to send it per post. It is not necessary, but it contributes to the completeness of the device: AC adapter, carrying belt, box, warranty card AND manual.
    Regarding susceptibility to taps or vibrations, it does not seem to be overly affected. If I tap the lid it does skip, but nothing that I would consider abnormal. Now, given that it works as expected, would you recommend replacing the capacitors? I might open it and see how they are (altough I am not looking forward to it. Removing the lower part of the housing revealed not only a virgin interior, but also a bunch of neatly organized wires soldered to the board).
    Overall, I am happy with the purchase. Later I'll give it a clean (it really smells like old electronics) and listen to it properly.
    Hyperscope, Jorge and Mister X like this.
    It's hard to believe there's no marks on the top face, it looks very nice. I usually only go for the square bodied players but they are hard to find locally.
    Eryan and Jorge like this.
  6. Eryan
    Eryan Member
    Bavaria, Germany
    I have to agree that boxy players have a charm to them. Here mine, side by side, after a very pleasant hour of listening (apologies for the bad lighting):
    To the TEAC itself: after a good hour of listening to it, and comparing against the Technics SL-XP5, it is a perfectly capable and nice player. It is not at the level of the XP5 however (my reference player, and an outstanding one IMMO). To my ears, the TEAC has good imaging and good separation. It does not distort at all, and the heaphone out is powerful. The bass is clear and full, but not saturated; and the treble feels a little less straightforward than the XP5. It has good resolution and properly reveals what is being played, but not with the level of detail offered by the Technics. This again is only my take on the players and not a comparison with numbers, charts and facts. It is however an unfair comparison: the XP5 is like a blanket of sound that wraps you around, very cozy and full. It simply offers a proper 3D image of what's being played (if that makes sense) with an absurd level of detail. It is perfect to surgically dissect the mixing on a CD.
    Regarding skipping, I didn't notice anything particularly concerning. During the one hour listening, it didn't skip once. Using it on my desk, it skips if I slap the desk a little. I have to tap the player with a little force to get it to skip, but it is nothing that I would call unusual.
    My goal with the experiment was not to define which one is better, but to get an idea of the nature of the beast. And I am happy to report that the little unknown TEAC is now a permanent member of my collection. I'll most probably open it up to clean it and apply new grease to the mechanical parts. Standard maintenance to keep it working many more years.
    It's a good time to be into CD's, I'm buying them around here for $1 USD. While I love cassettes, I can buy a CD and still pop it into a car stereo and listen immediately, my work van radio lost a channel on the cassette deck which is a real bummer.
  8. Jorge
    Agreed! what can be better than $1 per CD? Unlimited hi-res Tidal for $11 a month ;) ... or a two-CD-set for $1 :) !!! Which I got a few weeks ago: The Best of Doors two-CD set for a dollar! the only drawback is that I already have all Doors albums and seriously dislike Best-Of sets :eek: But - one dollar is a magic price. $1 pre-recorded cassettes I have yet to find, but since I never bothered with those it is probably too late to start now.
    tried to respond to the OP but cannot upload any photos, even at 600x400 pix below 100kB jpeg. Tried from home and now from my office but getting the same message, I must have been "blacklisted" by my favorite chatroom of S2G :oops::
    The following error occurred:
    A server error occurred. Please try again later.
    Sorry, I don't have any control of the forum financials and there hasn't been an update from WA in a couple weeks.
    I think one of the reasons physical media is coming back is that you tend to enjoy what you bought. I have thousands of movies I can stream, even then it takes me an hour to find something that I loose interest in and then turn on a youtube repair video.
  10. Eryan
    Eryan Member
    Bavaria, Germany
    It is indeed a good time to buy CDs. I buy all my albums used for a fraction of the price. And apart from owning the media, I enjoy the ritual of searching for a CD and sitting to listen to it, to listen with intention. Sure, my Plex server has all files uncompressed and o can stream from wherever in the world in the highest resolution. But there is still something very satisfactory in the simple ritual of going over my CD collection, finding a record that tickles my curiosity, doing the same with the cd players, and taking the time to enjoy the music without distractions (or at least as few distractions as two toddlers allow).
    True, Tidal and other services offer everything you could desire, but IMMO that takes away the need and the joy of listening with intention. Plus, I cannot stream to my old cd players :tongue:
  11. Jorge
    When at home and at my ‘sweet spot’ there is always music blasting from the speakers, but cannot say when and how much attention is being paid. Depends on the music, usually. But totally agree with previous statements! The effort of moving two hundred pounds across the room, taking LP from its sleeve, lowering the tonearm, and then making a return trip to the armchair – all this forces me to pay more attention to music. It also helps that LPs sound better than any digital I ever had :oops:
    back to the baby-Discmans:
    @Eryan - thank you for the tip – next time I am reviving this model I will pay special attention to what may go wrong with 1.2V rechargeables and will check if it can charge modern 1.5V Li-Ion rechargeable AA’s.
    If you decide to open it, pay attention how you manage laser focusing flexboard: it should be kept away from the lid limiter:
    Looks like we are in total agreement about SL-XP5 being one the best Discmans ever made. Glad you agreed with me that this “basic” model sounds much better than it should. Bright Blue 220uF ELNAs in front of the motor/laser drivers is an easy upgrade, fresh grease for the rod and gears takes more efforts:
    Since CD-3250 has a Shoulder Strap – it is presumed that one can walk while listening to CD. Unfortunately, most CD-3250 skip at the slightest tap – but the fix is a five-min job. For some reason, most of these have VR4 (tracking gain) set at its minimum, see photo where it is factory-set at around at 9:15 o’clock. It should be at 11 o’clock, adjustment is doable without any disassembly:
    Valentin and Mister X like this.
  12. Eryan
    Eryan Member
    Bavaria, Germany
    Down on the basement, when on my man cave, I also keep some music in the background. But usually one of two things are happening: the 3D printer is running, or I am trying to figure out why something doesn't work. As such, attentive listening is not possible. Hence, the gear I have there is good enough, but nothing special: the Philips CDC 925 is a chunky CD changer and a nice piece of equipment (and one I keep because I restored it to an almost brand new state) but nothing outstanding. I also have an old Fisher AD-9020 that I got for cheap, needing only a new belt. It has an interesting DAC inside, but the difference is very subtle when put against the Philips. And finally, a couple of Edifier R1280T active speakers which, again, sound nice and look good but are not intended to decipher what's being played; and they basically level out any interesting player sitting behind them. But they get the job done. Having kids and a wife with a low tolerance for my music taste forced me to dig more into the portable gear. As such, intentional listening is only possible with headphones.
    And don't get me started with Acetate. That is a rabbit hole that I am intentionally avoiding as much as I can. Not because I don't find it fascinating and potentially rewarding, but because I lack the space for it (both in terms of where to put all the stuff, and a dedicated listening space).
    Regarding the TEAC: I deeply appreciate your recommendations. I've lost count of how many players I've been able to troubleshoot thanks to you. A couple of questions:
    1. Regarding the flex board: you mean the orange flex cable going into the white connector at the bottom of your picture? Thanks for the tip. The chances of me mangling that flex cable without your advice are high.
    2. Regarding the capacitors: I tend to use Panasonics when replacing old caps. When you say "upgrade", are the ELNAs considerably better, or do they affect the player's behavior in any way?
    3. I would have never considered touching the tracking gain on this player, at least not without a service manual. But your suggestion makes a lot of sense. I have to check how mine is set, but considering that the TEAC is the lost sibling of the tripplet, chances are that mine also has the tracking set to a minimum.
    4. I would like to perform some mechanical maintenance also (apart from any suspicious cap). Do you happen to have a service manual for this model? I have searched online with little success (I've tried all 3 model variants). I could only find a service manual on servicemanuals.net, but it is $17 and I have no way of checking if it is indeed the service manual or the user manual (have had mixed results when buying manuals from that side, hence the doubt).
  13. Jorge
    Wise man talking... also good for your toddlers' College Fund ;)
    TEAC:
    1) Yes, that's it! Just take a closer look on how it is managed, before removing the mainboard. I also add some tape to keep it away from that metal thing
    2) I like audio-grade Nichicons and Rubycon electrolytics. Panasonic makes the smallest-sized caps - I use them too. The Grand Idea is to upgrade C110 and C210 from 100uF to 220uF, to tighten the bass. Master Kaosun (kaosuncd.com, he is The God of Discman repairs) even goes for 330uF. I hear that "size matters" and prefer smallish caps for h/p coupling . Voltage rating does not matter here, even 2V caps (not produced no more) are safe to use. Nichicon 330uF polymer caps are small and can be used. But they are boringly "neutral" and since I just love distortions, I do not use them for my own Discmans. NOS 220uF/4V Black Gate electrolytics from Rubycon are my favorites, if you can find them
    3) Service Manual for this Toshiba describes TG adjustment - DO NOT FOLLOW!!! This was the first Discman when Toshiba (finally!) realized that Sony lasers are much (very much!) better than their own, but it looks they did not bother to learn how to calibrate KSS-220A
    4) I uploaded XR-9421 Service Data here:
    Good Luck!!! :)
  14. Eryan
    Eryan Member
    Bavaria, Germany
    Good day!
    I just wanted to give a short update on the player. I had some time yesterday to open it and give it some maintenance. First and foremost, the player was incredibly clean inside, with all capacitors in very good shape (no leaks, no bulged caps, no damages on the PCB). As such, there was little to be done in that regard. I am not able to properly add pictures to the post (for some reason it doesn't work). But the links should work.
    https://photos.app.goo.gl/8FqrDmJ7MZhkGob26
    Then, the output caps were replaced with equivalent 220 µF, 6.3V Panasonics (same size). A PCB with thru-hole components only and leaded solder makes the whole affair very easy (albeit somewhat unhealthy). And finally, I gave the tracking gain potentiometer a nudge to 11 o'clock. The mechanical parts were clean and the grease wasn't hard or dry, as such I saw little point on disassembling any further.
    First and foremost: the tracking gain adjustment is a game changer. The player is rock solid now. I was having some issues with the player skipping during the first 1 or 2 tracks of some CDs. That is solved now. It is also way more resistant to taps or vibrations. Also, the routing of the laser flex cable is a fiddly affair, but I managed to route it cleanly. Thanks a lot for the tips.
    Regarding the output capacitors: I am not able to immediately notice a change in the bass (however, I haven't listened to a lot of music with the player after the modification). What I did notice, I believe, was that the treble is more pronounced. I don't see why the output caps would have an impact on the treble, but I could imagine that the change is not because of the higher capacitance (100 µF to 220 µF) but the age of the caps. But again, without having a back to back comparison, it is hard to tell if the treble trully was affected.
    The adventure wasn't without challenges however. After reassembly, the player refused to start and produced a very quiet pulsating "beep" on regular intervals. I rechecked the wiring 5 or 6 times I believe. The player showed no signs of life with both batteries or the AC adapter. After a solid hour of troubleshooting (and slightly panicking), I found the culprit: the ground wire of the battery had shorted a neighbor pad and was preventing the player from starting. The ground wire was held in place with a rather massive blob of leaded solder, which kinda spilled outwards when I removed ground the wire to remove the PCB, shorting the pins in the yellow circle below. Removing the solder blob and cleaning the area resolved the issue and allowed the player to start again.
    https://photos.app.goo.gl/ezr9BSsRnoWSuMWp8
