Panasonic RQ-X11 repeating reverse error
Discussion in 'Tech talk' started by Ridvan, Sep 10, 2021.
  1. Igor62
    Igor62 Member
    Ukraine
    С интересом прочитал про Panasonic RQ-X11. Недавно получил нерабочий плеер, естественно поменял плохой ремень. Плеер заработал, все функции работают и автореверс. Но присутствует повышенный механический шум, можно даже сказать периодические постукивания в механической части. Спасибо за совет. Была ли у кого-нибудь подобная проблема с плеером?
  2. Michiel
    Cassette Paradise
    Today I was working on a dead Panasonic RQ-X11. The motor was working, but otherwise, no sound or anything else. After I connected the jumper from the positive terminal to the ribbon cable connection of the control panel (as Ridvan suggested), it came back to life! Thanks for the solution! :)
    After that, it played fine in forward direction. But in reverse, it jumped forward again after a few seconds. After re flowing IC4, that problem disappeared too.
    Mechanically, it makes some noise, just like the one mentioned above with Igor64. Probably a dirty gear I guess. But I don't hear it in the audio. Hopefully, it will go away after a while :)
