Sony DD series step-by-step repair guide for beginners
Discussion in 'Tech talk' started by mihokm, Sep 3, 2017.
  1. jacobsteel
    jacobsteel Member
    Gothenburg, Sweden
    Seriously good post! Thank you! :D
  2. 16s
    16s Member
    Does everyone see the blank space?? Has the guide been posted anywhere else? Thx
  3. Guy Doss
    Guy Doss New Member
    San Jose, CA
    Yes, I think the guide is a work in progress!
  4. Guy Doss
    Guy Doss New Member
    San Jose, CA
    Hey, thanks for the confirmation. Spotters guide question, do all the Walkmans with this control layout have the same central gear? Do you know Mihokm?
  5. renzgi
    renzgi Member
    Switzerland
    Yes, all of these Walkman have the same gear. There are few WM-2 and WM-5 with different gear, but they never break.
    I know mihokom only from the forum. What he did for us is great.
  6. Guy Doss
    Guy Doss New Member
    San Jose, CA
    Yes, he is a good guy to know. He says he has over 300 portable tape units so he can measure the exact correct size belts. Amazing.
  7. mihokm
    mihokm Active Member
    Slovakia
    Guide is finished. This is the first version, without special instructions for WM-D3 and WM-F5. These will come later, next year.
    Over 50 pages of reading. It took me quite long time to finish it, that's why I was not active on this forum.
    Please, wait for the instruction about guide location. Then I will delete this "not finished" guide from this thread.
  8. Guy Doss
    Guy Doss New Member
    San Jose, CA
    I am in awe of your skill and dedication. Thank you for making this hobby so much more productive and enjoyable. You deserve a medal, or an of award of some kind.
  9. buzbox
    buzbox Active Member
    Installed the first gear kit in one of my dd's. Thanks Marian for your effort in getting these gear kits made. Superb!!
  10. mihokm
    Slovakia
    Since I get lot of questions, when and where the DD repair guide is available, I post you link here:
    https://drive.google.com/file/d/0B31_GyAAeWa8SDZ5U0k2SUVLWGs/view?usp=sharing
    It is only draft version and it needs some improvements. Plus I have some more things to add there. But almost everything is there, including slider repair. Hugo will help me with it and he will publish it on his walkmanarchive.com site.
    Feel free to use it. And wait for the final version :)
    Command8 and 16s like this.
  11. Guy Doss
    Guy Doss New Member
    San Jose, CA
  12. T-ster
    Excellent guide, this covers so many issues :thumbup:
  13. enryfox
    enryfox Active Member
    close to Milan (Italy)
    Excellent guide, I never considered how many things can brake in a DD walkman !
    Actually I think you are a bit too "scary" on the tape path adjustments; the left tape guide requires essentially a transparent cassette and a magnifying glass to verify the correct alignment.
    Adjusting the head azimuth on a playback-only device is rather simple, it can even be done "by ear" with a good pre-recorded cassette (e.g. those made with HX Pro). I checked that type of adjustment with an oscilloscope and a test tape and it is typically correct within +/- 90 degree of phase shift between left and right. As a reference all those heads with fixed azimuth of auto-reverse walkman's are typically phase aligned with the same tolerance.
  14. buzbox
    Done 5 DD's with this kit so far and results are always good. A great reproduction kit!!
  15. 16s
    16s Member
    i think i have either a slightly bent gear arm or centre gear axle. I havent been able to get my DD30 working with the new gear. Hopefully with Marian's extra instructions i can try to fix it.
  16. wm_dan
    wm_dan Member
    UK Yorkshire
    wow and flutter bang on spec with Marian's DD gear and Capstan Ring installed.
    Ordering more parts soon!
  17. wm_dan
    wm_dan Member
    UK Yorkshire
    Just read the dd repair guide beta, awesome stuff
    Cheers Marian
  18. 16s
    16s Member
    By capstan ring do you mean the one that sits in the Coil housing? What colour is it?
    thanks
  19. wm_dan
    wm_dan Member
    UK Yorkshire
  20. 16s
    16s Member
    ahh, that one. i thought meant the one Marian calls "tiny plastic ring inserted on the capstan axle."
    thanks
