Sony Walkman WM-33 Belt Clip
Discussion in 'Tech talk' started by Luke Flux, May 18, 2023.
  1. Luke Flux
    Luke Flux New Member
    Isle of Wight
    Hi
    so I recently bought myself a Walkman WM-33, works perfectly, and the belt clip is a bit worn and flimsy. Does anyone know what type of screw is needed for the screw hole on the back because I’m struggling to find a replacement official belt clip, so I’m trying to find a custom one but I don’t want to buy one when I’m not sure what size screw the screw hole requires.
    You could probably get some ABS sheet, you can cut it with woodworking tools and glue it with ABS cement. Build up one side and drill a hole through it. I just check one of my Walkmans but my days of identifying bolts visually are long gone, I'd bring it to a hardware store and go through the boxes until you find the right size, our stores usually have a ring of bolts hanging up that you can also use.
    Adam Savage uses Styrene, it might be easier but I don't know how strong it is.
