Sony WM-2
Discussion in 'Tech talk' started by JUAN ANDRES MONTIEL DIEZ, Nov 20, 2021.
  1. Valentin
    Tape guide, if the lock paint is original leave alone. Tape guide is fixed, not related to the head bridge and not the cause of your problem.
    In regard to head bridge, there's only one thing to check: if it moves all the way into position or just partially when the plastic slider pulls it up.
    However given what you say about takeup torque being very high, incline towards that being a problem rather than the pinch roller.
    Of course fact it sits at an angle should be solved later on, but not the main concern right now.
    Likely issue is clutch is frozen or touching something and can't slip properly.
  2. chromer-ccm2
    chromer-ccm2 New Member
    United States
    Yeah on a second inspection the whole pinch roller is making contact when it play (and powered). I made the mistake of seeing that when the walkman wasn't powered and thus didn't pull the head unit forward. Checking the head bridge and the slider it does move it all the way up.
    What should I be looking for with the clutch assembly. I'm not quite sure based on the service manual which parts I should be looking for. I assume I'll need to take the takeup gear off to see below it.
    Adding some images finally of the board and motor assembly:
    Marked the clutch on the attached picture.
    However can't know if this is actually the problem. If you don't have a good feel of what a normal takeup torque feels like, it might feel it's too high even if it's not.
    Hence why I would suggest to compare it with any other walkman/cassette machine you may have in order to get a good feel.
    Test with stopping the takeup reel should be done with 2 fingers and you shouldn't struggle to stop it, but it should take a bit of force to stop it.
  4. chromer-ccm2
    United States
    It was completely seized up. I popped off the retaining washer and popped the clutch and washers and they were all very heavily stuck together. I'm cleaning them now.
  5. chromer-ccm2
    United States
    Thank you So much Valentin! I got the clutch parts off easily enough and cleaned them with just iso and reassembled (wasn't sure if they needed grease or oil, I can always go back in later). Wired back up and IT PLAYS GREAT! I had to adjust the tape speed by ear best I could (don't have a test tape, I'll worry about that later). The wow and flutter is there, but it's surprisingly minimal. I'm always amazed at how well these old machines will hold up.
    One last question if you could: I'm missing one door hinge screw for the cassette cover. I'm having difficulty finding the right screw (and for some reason the service manual doesn't have the actual specs for that thread and length). Any help on where to source a replacement would be much appreciated.
    Clutch does need some grease on the middle, where there's friction between it and the middle plastic hub.
    If you want a small drop of oil can also be added on the nylon washer that separates the magnetic part from the metal disc.
    None of the 2 is critical, but it will reduce wear over time.
    For others reading this thread, this type of clutch is magnetic, so oil on the nylon washer will not change the takeup torque like it would on a clutch with felt pad.
    Door hinge screw is pretty unique, don't think you can find a replacement for that. Screw is M1.4 thread (there's only one pitch for this) x 3.5mm (length below head).
    However this screw is custom (larger head, thicker part without threads) and a normal one won't work right.
    My recommendation is to get a proper replacement somewhere, from a donor unit or someone who has many parts like tomtom87.
  7. chromer-ccm2
    United States
    I ordered a new pinch roller from Fix your Audio just to keep refining this thing now that it works (along with a test tape). So I'll do another full tear down to get the clutch some oil then. They also sell a general grab bag of walkman screws so maybe I'll get lucky and one will be in there, otherwise this might just be a custom job somehow. Sadly I think the screw was missing because it broke off partially in the hole. Might be SOL without fully replacing that bracket from a donor.
  8. Valentin
    For the screw, ask user tomtom87 in a private message. Chances are he has it and will be cheaper than buying a donor.
    Kit fro FixYourAudio has only M1.4 screws and you will find one that can work temporarily, but as stated it's not the right solution.
  9. chromer-ccm2
    United States
    Yeah, bigger issue is that looking closer at that bracket hole the screw did in fact break off in there, so there's very little threading available and it wouldn't be able to screw down tight enough anyway. Also the threaded insert itself is actually loose and spins in it's hole...so that seems like something only a donor swap would fix. That or a lot of extra work to replace the threaded insert.
  10. chromer-ccm2
    United States
    Had a new issue develop ahead of replacing the pinch roller: The left audio channel now has a small "click" in it. Resoldering the connection has really just left it a bit muted (probably gotta go back in and clean up the wire itself and ensure a more solid bundle) without solving the click. I also checked the grounding wire by the volume control and that's seemingly fine. Any tips on further diagnosing this? It's a fairly regular click every few seconds. Cleaning out the headphone jack and cable ends on the headphones themselves did nothing (Click is only when listening on the walkman).
  11. chromer-ccm2
    United States
    Amendment to the above: Re-soldered the ground and Left audio channel connections, applied deoxit to the both headphone jacks and the tape type selector switch and...rerouted some wires around the motor compartment? This did nothing at the time and the clicks persisted with or without a tape, then I left it to sit over the weekend. Checked some stuff again today and ran a "Realistic Cleaner and Demagnetizer" I found at my in-laws place through the player.
    The click persisted for a few beats, then the clicks got further and further apart (originally roughly every 4 seconds, then down to every 30 seconds) till it seems they've finally stopped. So maybe it just needed to be demagnetized or the deoxit found something causing a problem and just needed some time to work, but who knows.
  12. Valentin
    Without an audio recording, "clicks" can mean many different things.
    If what you hear are pops similar to ones vinyl discs make when they're dusty, failing output capacitors can cause such a symptom.
    What you say about demagnetizer eliminating the clicks is interesting, never seen or heard a magnetized head to have such symptom.
  13. chromer-ccm2
    United States
    New development I found: The pop was intermittently coming back. Checking again the tape head had a tiny spot of buildup I had missed before. I had worried it was actually a wear spot on the head since I'd used the tape head cleaner recently (which could have been leading to a short and the pop), but some iso and a swap took it off and now the pop is gone again. Fingers crossed that was all it was.
  14. chromer-ccm2
    United States
    That was not it. I think I'm beyond my abilities here and need to find an experienced repair person. I don't have the equipment currently to dive into testing or replacing capacitors if that's what the issue is.
  15. Valentin
    Wouldn't worry too much about the head, since it can be lapped. However don't see how dirt/wear on the head would cause pops.
    I would suggest to replace just the 2 x 220uF on the output and see if anything changes.
    In regard to grounding, 2 things are to be kept in mind:
    1. The mechanism chassis (and the motor case especially) needs to be connected to the circuit ground through a low impedance path.
    2. There's a copper foil near the potentiometer on the case which also needs to be grounded.
  16. chromer-ccm2
    United States
    I'm going to go at least get a multimeter today to at least roughly gauge if anything is going bad, but since it's still working I'm not confident a minor fault will be apparent that way.
    I've done my best to ensure that the grounding path from the potentiometer to the foil and the larger copper pad are intact. I have noticed that the foil itself that's right next to the potentiometer has gotten a little chewed up in the past from assembly/disassembly. If that were in contact with the frame would that cause a short that could be causing this?
    EDIT: Nevermind on that last question. Obviously if that were the case then testing it with the cover off would see the pop go away and it doesn't.
  17. chromer-ccm2
    United States
    I got some tools so I can finally record a sample. 26 seconds, features 3 pops.
  18. chromer-ccm2
    United States
    I really don't get the nature of this issue. I just rewound a full tape in it and the pop is gone for now.
  19. chromer-ccm2
    United States
    Potential new thing I just discovered: If I rewind without a tape it will shut off after a few seconds. Not disengage, the button stays down, the power just cuts. It will rewind fully if a tape is in, however when the tape is fully rewound it won't mechanically cut off.
  20. Valentin
    There is no mecahnical auto-stop on FF/REW on these devices, just electronic auto-off to stop the motor. So this behavior you describe is normal.
    In fact mechanical auto-stop oln FF/REW is not a common feature, can't think of a walkman (without logic control) to have this.
    In regard to the pops, incline towards a grounding issue although swapping those 2 output caps is also worth doing.
    The copper foil should not make a short on the PCB (it has some protective film on it). If that film is gone, add some tape yourself.
