Sony WM-GX670 belt source needed in the US
Discussion in 'Tech talk' started by euroflash, Jan 9, 2024.
  1. euroflash
    euroflash Active Member
    Oregon
    @radiorich Thank you, Richard.
    I already got the clutch gear, and possibly have a lead on a NOS flywheel. With some good luck, I will have all the parts soon.
    Best,
    Alex
  2. euroflash
    Oregon
    A quick update: I installed the belt from DeckTech and it is a perfect fit! The slack is gone, and the tape speed has stabilized, mostly. There's still some difference between FWD/REV, but W & F has been reduced significantly and even audibly. I also reset the playback speed back to the previous levels, since the inner capstan tension has increased. @Valentin - thank you so much for the lead on the Mana_Tree vendor.
    The clutch gear replacement arrived also. This is the next step. I will keep you updated on the progress. Thanks for all the help!
    RTB, Emiel and Valentin like this.
  3. radiorich
    radiorich Active Member
    Washington state
    Sony tr610.jpg Hello EuroFlash,
    Nice that Sounds good this last weekened I restored My Sony model TR-610 Am transistor radio it really works well after replacing the smalled Can electrolytic which had 3 electrolytics in on can .
  4. euroflash
    Oregon
    @radiorich Very nice! I love seeing those classic gems brought back to life.
  5. radiorich
    Washington state
  6. euroflash
    Oregon
    Just a quick update, a bit delayed. I had to reorder the clutch gear as it arrived cracked. The eBay seller had integrity and took care of me with the new one.
    Once again, a complete disassembly and desoldering followed. I examined the flywheel for cracked gear, and it was negative. Whew! (Valentin suspected it was the cause of high-frequency clicking noise).
    Once I installed the new clutch gear, the mechanism worked without issues. I was surprised to see that a tiny crack in the clutch gear can cause so much trouble, this was a new learning.
    In summary: a new and correct belt and a clutch gear replacement did the job!
    @Valentin, thank you for your expertise and guidance. I appreciate it and it helped to narrow down the problem.
    A side note: working on these tiny Walkmans is not easy. It requires dexterity with tools, good eyes (or a magnifying glass), and a ton of patience.
  7. radiorich
    Washington state
    Euroflash ,
    Sorry to hear that about that gear and yes who would think that little crack would make that much diffrence but it does anyway I also restored a Sony Tr-620 and I won a General Electric built in 1957 am transistor set and I have two tube car radios to restore for customers !
    Sincerely Richard
