Walkman 150 clutch repair
Discussion in 'Tech talk' started by bub, Feb 23, 2017.
  1. autoreverser
    now posts like this are the reason why i like this forum more than any other forum in the f***ing internet...
    :thumbsup2:
    Sly. and Boodokhan like this.
  2. bub
    bub Active Member
    It's very easy to replace the caps in this model. On one of my copies the old caps were going out, on the other it was still ok, but I did it anyway.
  3. Pomidor
    Pomidor New Member
    Russia, Krasnoyarsk
    I tried to do clutch repair and opened up my walkman, but I didn't expect to see this IMG_20190810_224518.jpg
    IMG_20190810_224938.jpg As I understood it, last owner just changed the cracked gear with not exactly same one, so only play works fine, but "green button", FF, REW aren't. I really don't know is he bad one, or my saver))
    Maybe someone possibly find, where to find the new gear instead of cracked one, or I have only way to buy broken walkman and take gear from it ?
  4. bub
    bub Active Member
    That gear is probably too tall and preventing the other gears from meshing with the top of the clutch drive gear. If this is the case, it might be worth a try sanding it down.
    You should be able to find another walkman with this mechanism as they were very popular. Look for the same buttons or an "EX Head" script on the reel table.
    Pomidor likes this.
  5. Pomidor
    Pomidor New Member
    Russia, Krasnoyarsk
    You are genius !)) Could you measure the height of the gear for me, please, or it will be difficult ? Maybe I could fix it.
  6. stereomecha99
    stereomecha99 Active Member
    United Kingdom
    Following this thread. What glue do you use for this process? Also shame the member producing gears never came back.
  7. bub
    bub Active Member
    I don't have a gear with me at the moment to measure, but check if the clutch drive gear is touching the surrounding gears in FF/REW mode.
    There is no glue that can hold to nylon/delrin permanently, it's only there temporarily to give time to "weld" the gear in by melting it.
    There are people doing 3D printing for some cassette deck gears that are quite high in quality, but I suspect there's not many that want to fix a WM-150 mech.
    (There are more desirable models from a collectibility POV, less 550C)
  8. frblaze
    frblaze New Member
    Paris France
    Hi Pomidor
    If you are still looking for a clutch to repair your WM-150 I have one from a WM-AF605/BF605 they are the same, it’s repaired but fully operational, I test it for hours.
    Greetings
  9. naanmic
    naanmic New Member
    India
    Hey me too looking for one
  10. rupi99
    rupi99 Active Member
  11. Raul
    Raul Active Member
    Szczecin
    How do you remove those gears? I will be repairing my Walkman and I don't want to break it.
  12. kmare
    kmare New Member
    toronto
    Bumping this thread. I have a very nice example of a WM150. Ive replaced the clutch gear and belt. However the reverse mechansim is sticky.
    The large white gear under the clutch gear does not swing between pickups - its getting stuck somewhere. The mechanisms are all well oiled and seem to move freely.
    Is this related to the clutch? is it slipping? The mechanism is incredible complex, really amazing engineering for the time.
  13. Raul
    Raul Active Member
    Szczecin
    Mechanism of WM-150 is cheapened version of better WM-10/100/501 mechanism.
  14. kmare
    kmare New Member
    toronto
    Following up -- WM170 is recapped and sounds great. My issue now is isolated to the transport. Looking if someone can confirm if the belt (new from fixyouraudio/mihokm) or transport is the issue
