Walkman Internal Photos
Discussion in 'Tech talk' started by mrn, Jan 17, 2017.
  1. mrn
    mrn Member
    germany
    15. JVC CX-F5
    miniature machine with radio and motorized head engagement
    IMG_0529.JPG IMG_0536.JPG IMG_0571.JPG IMG_0570.JPG .
    belt size: 8/13 or 9/13
    center gear seems to have problems: machine creates traffic jam even after new belt is installed.
    Valentin and Brutus442 like this.
  2. mrn
    mrn Member
    germany
    16. Aiwa HS-J09
    common problem: broken center gear.
    the 4 machines below share the same mechanism.
    center gear is under huge load when switching the playback direction (fwd, rwd).
    if the machine jams the tape, the problem is most probably the broken gear (the spring creates tension when removing the gear and jumps off, too).
    IMG_20170305_225743.jpg IMG_20170305_234013.jpg IMG_20170305_234551.jpg IMG_20170305_235815.jpg
    Kabuff and Valentin like this.
  3. mrn
    mrn Member
    germany
    17. Aiwa HS-J02
    Robust, heavy player /recorder, reverse, Radio, separate FM antenna.
    Not easy to change the belt, but worth it!
    Caps still ok, Machine just works!
    IMG_20170316_203702.jpg IMG_20170316_204228.jpg IMG_20170316_203915.jpg IMG_20170316_203924.jpg IMG_20170316_205147.jpg IMG_20170316_213557.jpg
  4. nickeccles
    nickeccles Well-Known Member
    Littlehampton West Sussex
    Love this thread :thumbsup:
  5. funkitall
    funkitall Active Member
    Nottingham
    Superb MRN....
    Although I am petrified of dissecting my "babies"...
    I do have a TPS-L2 that needs a new belt....and if a simple solution I may give that a go...
    Any chance of "dissecttion"?
  6. mrn
    mrn Member
    germany
    @funkitall: no experience with TPS-L2 here.
    you can try google images to find disassembled L2s.
    good luck (and don“t forget to share ;).
  7. bub
    bub Active Member
    EEVblog did a teardown on a TPS-L2, great for reference. The service manual is also helpful for disassembly.
  8. funkitall
    Nottingham
    Cheers for your input......
  9. mankamaz
    mankamaz Administrator Staff Member
    madrid,. spain
    Fantastic post!!
    Specially for the Sony 190/B603/AF605 series
  10. Helaba
    Helaba Active Member
    Belgium
    Hi Peter
    As always, Fantastic work!! Thx
  11. cavdel
    cavdel Member
    Luxembourg
    Aiwa HS-P505 mkII
    Valentin, Mister X and sickly_b like this.
    Great thread! but it needs to be moved and what happened to mrn?
  13. cavdel
    cavdel Member
    Luxembourg
    Sony WM-EX122, a very basic model
  14. Yari
    Yari New Member
    Ukraine
    Hello, MRN. I see you have Sony WM-EX512 Walkman in your collection. I just bought this player too and would like to change the drive belt in it: I know the guy in Ukraine who produces them (already purchased for my SONY WM-EX674 and it was quite good and rather cheap) but to order from him you need to tell him the specs. Have you ever got to know the dimensions of the one for EX512? Thank you in advance!
  15. Emiel
    Alternatively, you can order one directly from here: https://fixyouraudio.com/product/belt-sony-wm-ex512/
    I have ordered several belts in the past, worked out quite well.
    Yari and Valentin like this.
  16. Kabuff
    Kabuff New Member
    Hannover, Germany
    The Aiwa HS-P09 share the same mechanism (2 ME 7).
