We Are Rewind Cassette Player
Discussion in 'Chat Area' started by Steve Grant, Sep 9, 2026.
  1. Steve Grant
    Steve Grant Active Member
    Vancouver British Columbia
    https://www.wearerewind.com/en-eu/products/lecteur-cassette-bluetooth-orange-serge
    Technical details
    • AUDIO SPECIFICATIONS
      • Frequency response: 30 – 14,500 Hz ± 3 dB
      PERFORMANCE
      • Compatible with compact audio cassettes, Types I to IV
      PLAYBACK
      • 2-track stereo playback
      • Frequency response: 30 Hz – 14,500 Hz with Type I cassette
      • Signal-to-noise ratio: 50 dB
      • Distortion: 0.3% typ.
      • Wow & Flutter: 0.2% typ.
      • Headphone output power: 2 × 2 mW at 32 ohms
      • Bluetooth 5.1 (compatible with most wireless headphones and speakers)
      • Not compatible with in-ear headphones
      RECORDING
      • Stereo recording via RCA jack 3.5 mm input (compatible with Type I cassettes only)
      • Input level: 50 mVrms to 200 mVrms typ.
      • Frequency response: 30 Hz – 10,000 Hz with Type I cassette
      • Signal-to-noise ratio: 45 dB
      • Distortion: 1% typ.
      POWER SUPPLY
      • Built-in rechargeable Lithium-Ion battery
      • Nominal voltage: 3.7 V
      • Nominal capacity: 2000 mAh
      • Battery life: approximately 10 to 12 hours
      WEIGHT
      • Approximately 404 g
      DIMENSIONS
      • 140.8 × 88.8 × 33.5 mm
    Did you get one?
  3. Steve Grant
    Machaneus likes this.
