WM-DD33 the most delicate part (play button)
Discussion in 'Tech talk' started by Analogtape, Mar 8, 2020.
  1. Rok
    Rok New Member
    Slovenija
    Hello.
    I hope this thread is still alive...
    I got to the same problem.
    Is there any body who can help me with a spare play button?
    Regards, Rok...
    Ask Tom Tom, he is likely to have spare parts.
    Want to add something myself. This part is likely breaking due to the fact it was removed incorrectly. Have repaired many DD walkmans and this part never broke.
    How I remove it is with a pair of tweezers as indicated on the picture attached. Put the tweezers underneath and pull up.
  3. theLAG80s
    theLAG80s Member
    Does anyone know if this button can be substituted for a WM-2 play button?
    Unfortunately no, the DD33 button is unique to the DD33.
    The internal green part of the button is compatible between all DDs (in the sense it will fit in any mechanism), problem is the outer ornament is different and also the side of green part that goes into the ornament.
    - WM-2, WM-5, WM-DD, WM-DDII have same play button;
    - DD100, DDIII and DD30 have the same button;
    - D3, DC2 and DD33 have buttons unique to them; DC2 is compatible with DDIII type but has black ornament instead of silver.
    Emiel and theLAG80s like this.
  5. dom69
    dom69 Member
    Switzerland
  6. theLAG80s
    theLAG80s Member
    I tried this @dom69 and. . .it worked! I've never seen a complete play button but I tried "sodacrete" using this thread's images as reference and it worked after a few attempts.
    There are some limitations because this "flag" is more complex than a broken switch. I was not able to make the ridges on the bottom that keep it from coming out when you press stop. And I have yet to make it 1mm thin without it breaking so it doesnt get jammed in the button sleeve.
    What I made was rushed but I think with the right patience this a possible solution for the DD33 play button.
  7. dom69
    dom69 Member
    Switzerland
    Excellent! Happy it worked - you will get there with patience indeed!
    Bravo :)
  8. Analogtape
    Analogtape Member
    Bern Switzerland
    I started this thread a long time ago and got some great help in this Forum -thanks again.
    In the meantime I found out that the play button can be removed much easier if you press the FF and REW button at the same time :)
    So no more buttons break.
    Nevertheless, by curiosity I did some experiments with my 3D printer. After many attempts, I finally got a play button that works. I guess in terms of accuracy a part like this is the limit of what can be made with an FDM printer.
    It has not exactly the same shape as the original part, but it has all the surfaces needed for it to work. I suspect the original button has certain shapes that came from the limits for an injection molded model.
    Some WM-DD models have a "green dot" instead of an arrow and on some the arrow is in a different position. This can be handled easy in the construction file for the 3D printer.
    If anyone is interested in the .stl or .f3d (Autodesk Fusion) file, just let me know.
    Black Fingers and Valentin like this.
  9. dom69
    dom69 Member
    Switzerland
    Impressive, @Analogtape! I'm indeed interested in the .stl file, if you're ok to share it :)
  10. Analogtape
    Analogtape Member
    Bern Switzerland
    Here you go.
    Please don't criticize because it's so bunglingly constructed :noway:.
    An SLA print would probably be better. Unfortunately, I don't have one.
    Black Fingers, Deb64 and Valentin like this.
  11. dom69
    dom69 Member
    Switzerland
    Looks really good, bravo! Will try it at some point :)
  12. theLAG80s
    theLAG80s Member
    Just tried the print I am super impressed. Works perfectly! Now I have the limited edition dd33 with the black button:boogie:
    You are a walkman hero @Analogtape
    Analogtape likes this.
  13. BobKelso
    BobKelso New Member
    United States
    This is amazing news! Last year I tried fixing my play button with glue and some thin wire. Its held so far but I'm always worried its going to break again so I'm going to try this one.
    @Analogtape By chance have you modeled the fast forward and rewind buttons for the DD-33? Fast forward is broke on an extra DD-33 I have and its just been sitting around since i cant find replacement parts for those buttons.
    Thanks for providing the files for the play button!
